Paxton Supercharger?
Old Mar 7, 2002 | 06:16 PM
Xtreme Racer 86's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: TH700R4
Do any of you know the part number for the paxton supercharger kit that will fit a 1986 Tpi motor? The 86 has a V-belt set up instead of a serpentine. I have seen the kit before in Summit but, i can't find it anymore. If any of you have seen this kit or know the part number please respond.
Old Mar 7, 2002 | 06:58 PM
LIL QIK's Avatar
The paxton that you're talking about, I don't think they make any more because it was a ball drive unit and they were phasing all the ball drives out. Unfortunately the Novi's don't come for the thirdgen unless you want to make your own brackets. You might want to consider the ATI or I think that Vortec still makes one for the thirdgen. Just my input.........I could be wrong.
Old Mar 8, 2002 | 12:56 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
you can't buy it anymore...your best bet is to convert to serpentine and buy a blower set up for an 88-up.
Unless you want to find a used paxton....they come around sometimes. That's how i got mine.
Old Mar 13, 2002 | 11:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
when I contacted paxton for a customer about 10 months ago they said to check summit and sure enough summit still had "1" left of this new/old stock it had an SN series head unit but the NOVI upgrade was cheap through paxton but the customer didnt get it. where did it go who knows? get the part number from paxton and do a summit stock check and they may still have it.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
