Ok, you guys were right....
Old Mar 21, 2002 | 08:36 PM
KS91Z28's Avatar
my engine has too many miles on it for a supercharger. I had it on the Dyno tonight and the best it could do was 284hp at 8psi boost. I think it actually made the engine worse. I have a ton of blowby, (which is 10 times worse now). The question is now what do I do? I could rebuild the engine back to stock for probably around $1,000 or I could buy a crate engine for around $2,100. I want the bottom end to be tough enough to handle whatever I throw at it in the future. I need your guy's advice.
Old Mar 21, 2002 | 11:31 PM
NTChrist's Avatar
ZZ4! Forged bottom end!
Except for those iffy hyper pistons...
Of course, there are a lot of 4th gens running boost/nitrous with hypers.
If you're not going too radical, I'd go ZZ4 shortblock, and probably be able to swap a lot of your current parts over to save some money.
Old Mar 22, 2002 | 01:13 AM
89ProchargedROC's Avatar
just freshen your stock motor
take it apart and re-ring it and throw in some cheap TRW pistons
Old Mar 22, 2002 | 09:48 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
i second that. If you're on a budget you can't beat that.
zz4 or a crate motor is not worth the money.
Old Mar 22, 2002 | 10:04 AM
KS91Z28's Avatar
Will the TRW pistons hold up to a little abuse?
I figured while I have it apart, I'll put in a fresh cam and lifters, oil pump and have the heads reworked.
I also thought about getting a new set of injectors. Would you guys recommend going through the dealer and getting the stock ones, or is there something or somebody better that you guys would recommend?
BTW, I really appreciate your guy's advice. :hail:
Old Mar 22, 2002 | 10:12 AM
Well i was very tired when i posted that last night
YES TRW's will hold up to a ton of abuse, i know people who are funning in the 9s on them
But the problem is that they only make them in .030 overbore and not stock bore size i believe
so you would have to bore your motor over
also TRW doesn't make the pistons anymore, you have to buy them through Speedpro
Old Mar 22, 2002 | 10:17 AM
KS91Z28's Avatar
So I guess I'll just have to wait and see how bad of shape the cylinders are in and go from there. If I don't need to bore it, what are some good pistons to put in at the stock size?
Old Mar 22, 2002 | 11:03 AM
believe it or not you could use some keith black hyperutectics and dont boost the crap out of them until you are ready to step up to a better piston
they are pretty cheap
Old Mar 22, 2002 | 11:09 AM
KS91Z28's Avatar
I plan on boosting the crap out of this thing later on down the road, (within reason), so I'd actually rather buy what I need right now so the engine will be ready for whatever I throw at it. Aren't forged pistons supposed to be good for boost applications?
Old Mar 22, 2002 | 12:28 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Yeah forged pistons are the best for boosted applications,but they are not cheap.I paid over $700 for the custom JE Pistons designed for 30 pounds of boost in my V6,and you need 8
The only thing I can tell you is get a good set of forged pistons,stay away from the Keith Black hyper-whatever pistons as they are more suited for mild n/a motors.
Steve
Old Mar 22, 2002 | 12:38 PM
KS91Z28's Avatar
I don't think I'll ever go up to 30 pounds of boost.
How about rings, cam and lifters?
Is there a certain type of ring I should get?
Would there be anything wrong with going back with a Crane cam? Should I stick with the stock specs on the cam?
Old Mar 22, 2002 | 08:54 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the TRW 350 lower compression forged piston is one of the cheapest performance pistons anywhere.
Old Mar 22, 2002 | 09:49 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
if you know anyone at a gm dealership you can possibly get a replacement crank that comes in their 383 crate it is a cast steel crank with a 3.80 stroke should hold up to the abuse you intend.you can use hyper pistons and get some longevity out of them but keep in mind tuning is everything.one big detonation is all it takes,but if you go on the safe side with boost and octane you'll do fine..030 over 350 with that crank should give you around 388.i've heard that these stump pullers are seriously mean pulling somewhere around 450 lb/ft when modded and about 375hp with only a mild cleanup on heads and a better cam than that rv/truck crap that they throw in it.
good luck
Old Mar 29, 2002 | 11:26 PM
Pete89Z's Avatar
good luck
Now wouldn't stroking a motor increase the compression, and increasing the compression increase the chance of detonation? Keep in mind that if you boost your engine you want to keep the compression down or even lower it. Just be sure to do research about the subject and it wouldn't hurt to buy a book on the subject.
Old Mar 30, 2002 | 11:07 PM
poncho9789's Avatar
Stroking the engine won't raise or lower the compression of the engine that is deterimined by the piston cc and heigth from the piston to the block deck,combustion chamber cc, and head gasket thickness combination you choose. I am also shure that he knows he needs to keep the compression down on his engine.
I would get a new gm forged steel gm crank good rods (powdered metal with arp wavelock bolts) and low compression trw forged pistons that would give you a good setup to run as much boost as you want to (within reason). Speed pro pistons are made by federal mogul and not over priced but not anywere near the cheepness of the old trw if they haven't raised their prices. If you want a bullet proof bottom end you will have to pay for it. You might also check into the summit forged cranks, PAW forged steel cranks and the eagle cranks they are cheep for what you get.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
