Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
I have a tech article to submit
Old Oct 29, 2002 | 05:25 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I wrote a tech article about re-routing your serpentine belt, but I don't know who to send it to. I have the article uploaded to my site at http://www15.brinkster.com/fbody/belt.html but I can zip the whole thing and email it if needed.
Old Oct 29, 2002 | 05:19 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
webmaster@thirdgen.org
Old Oct 30, 2002 | 06:51 PM
MdFormula350's Avatar
cool, so you can use the same belt right?
any difference noticed?
Old Oct 30, 2002 | 09:17 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
You can't use the same belt, you have to use a 98 inch belt which is a couple inches longer than the stock belt.
Old Oct 31, 2002 | 12:44 AM
FLYNLOW92rs's Avatar
I've always wondered where the AIR Pump was.....
Can you by chance post a pic of the routing where the pump is removed??
The one on the main site is weird....
Old Oct 31, 2002 | 07:28 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Pics of routing are at the link.
Also, by re-routing the belt in this manner, it makes it easier to remove the smog pump. I do not know what size belt would be needed with no smog pump however, so you would have to experiment in order to get the right belt length/tension.
apie2546
Oct 16, 2016 02:24 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
