Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
an idea...
Old Dec 10, 2002 | 05:04 PM
sublime7880's Avatar
an idea...
Ive been a third gen owner and member of this board for about a year now. when I fist joined up i knew little about cars and knew even less about performance upgrades. I have spent TONS of time reading threads and learning concepts and terms. This was a very time consuming process as In the begining I did not know the meaning of some of the terms being used and had to research threads for definitions. Often I did not want to ask anyone as I didnt want to feel like a dumb-*** or I didnt feel like it was worth another person's time (not to mention newbies often get flamed for NOT researching the boards). While this information can be found in threads, It is time consuming. I propose that a group of us get together and put together a "glossary" for newbies. This can only help our new members and reduce threads asking for this information. It can contain information such as what terms mean, and names and functions of common parts. Just an idea....
Old Dec 10, 2002 | 06:09 PM
MdFormula350's Avatar
not a bad idea...
Old Dec 10, 2002 | 07:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Good idea. I would just like to point out, I don't care how many times a question was asked, I'll do my best to help answer the question or tell them politely to do a search. I was once where they were, and I am still learning a lot. I expect people to treat me with respect on here when I ask a question and I do the same.
I know this was the first message board I ever posted it on, so everything was new to me, i didn't know about searching, or that certain questions occur all the time.
It takes as much effort to answer most questions as it does to reply in a rude way.
Old Dec 10, 2002 | 07:43 PM
Most members are very professional in their replies, Mainly this "glossary" would be used to save time both on the newbies part and the other members.
Old Dec 10, 2002 | 10:38 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
a good idea, indeed.
and i get tired of seeing the new members getting torn into for not doing a search.
we really need this.
and part of that has been implemented. i know jester has a sticky thread locked at the top of the carb board that lists some general info.
Old Dec 11, 2002 | 07:26 AM
Lets get a list together and do this, im going to start thinking of some terms ill post them here soon.
Old Dec 11, 2002 | 09:00 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I think it is a great idea! Good thinkin sublime7880. This would help the board for sure!
Old Dec 29, 2002 | 10:10 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
yea but wouldnt that let the immature members pick on the junior members because they think they are young and unknowing??
I highly doubt it would be a bad thing but I think its a good Idea but watch out
BTW you guys are great at keeping this at its peek performance
Old Dec 31, 2002 | 09:56 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Some1 would have to make it.
Old Jan 22, 2003 | 07:26 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Ill start it .. this is a good idea
Is there any company that makes "Altezza" style taillights for thirdgens?
-No unless you make them yourself custom
What can I swap in from a 4th gen F-body?
-So far Dash, seats, steering wheel, console, gas tank, T-56 transmission and rear end some with little or no alterations.
Does anyone make Headers for the 2.8, 3.1 or 3.4 Liter 60 degree V6's?
-Custom header shops can but theres no company making direct swap in headers as of yet.
Can I swap my 2.8 or 3.1 for a V8?
-Yes its fairly common to do this you will need the entire engine harness computer motor mounts and springs from a v8 donor vehicle.
Can I take the computer out of my car?
-Yes, the engine harness is seperate from the gauges and lights but it will be tough to make the engine pass the emmisions test.
Can i use a V6 transmission with my V8?
-Yes and No you can use the manual v6 transmission if you bolt on the proper v* belhousing and be gentle but there is no way to mount the v6 automatic transmission to a v8
Will a steath ram fit under my stock hood?
-Yes
Is there an aftermarket body kit for the 82-92 camaro?
-Yes its called the Eviluzone and it has very mixed opinions with our members.
Are there any remedies for sagging doors?
-Yes theres two things to check #1 the door hinge pins and bushings in which case there is a rebuild set available from GM and the door latch in which place the latch would need to be replaced.
Can i recover my headliner by myself
-Yes first pull down the headliner and remove the old material and scapre the foam off with a wire brush or something of that nature. Then lay down the new fabric and use some 3M spray adheasive to adheare the two together. Same to be doen with the sail panels and sunvisors.
Are there any shifters for my automatic that are a direct bolt in?
-Yes the B&M megashifter and the Hurst Dual gate both have console versions there is also the Hurst quarter stick that has a console version but has been discontinued.
Does the "Tornado" fuel saver acctually work?
-No its a gimmick
What is the easiest engine swap for the 2.8 and 3.1L thirdgens?
-A 3.4 block out of a fourth gen is as close as a direct block swap you can get for the 60* v6's and has significantly more power.
Can I swap my 305 for a 350?
-Yes but as long as your going carb to carb or tpi to tpi otherwise you would have to swap the computer and engine harness
Can I put a racing harness in my car without putting in a roll cage?
-Yes but its strongly advised you change the seat to a race bucket of some sort all you need to do is mount it to the floorboards
Can I take the airbag steering wheel out of my car and put an aftermarket wheel on?
-Yes you'll have to take the airbag wire out of the column though.
Is it possible to swap all my stock gauges for aftermarket ones?
-Yes and some places even sell templates for that application too
Whats the best spark plug for our cars
-AC Delcos seem to be the best as they are made specific for GM applications
Can I put GFX on my SC/Berlinetta/firebird?
-Yes you'll need to swap the nose and rear bumper and drill holes for the gfx
Just a couple of the questions seen day to day that get told "Do a search"
Anyone else want to finish or contribute?
Old Jan 22, 2003 | 09:57 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Maybe add something about turbo's (Sizing, HP/TQ, boost etc.) and supercharges and Nitrous. Cause everyone loves those power adders and those seem to be the most talked about topics. And hint something on porting plenums, runners, and intakes. Theres some of my suggestions
I find myself gettin flamed for the above. So good way to avoid this. Wasnt there somethin similar in another board. let me check it out and get back to ya's.
J
Old Jan 22, 2003 | 10:42 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
found it its a sticky on the TPI board
https://www.thirdgen.org/techbb2/sho...hreadid=151240
Andre#4
Dec 1, 2009 12:06 AM
1970 Buick
Sep 23, 2009 08:29 PM
RED_DRAGON_85
Aug 25, 2009 07:34 AM
Slouch
Members Camaros
May 18, 2008 03:03 PM
L98ina25thZ28
Oct 8, 2000 11:52 PM
