Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
test
Old Nov 16, 2003 | 04:33 PM
SharpSnake's Avatar
test
im tring to add a img to my post so i tested it here
[IMG]D:\Documents and Settings\Snake\My Documents\My Pictures\C10_350.jpg[/IMG]
Old Nov 16, 2003 | 04:47 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
this thread doesn't belong in this board - but I'll try to help you anyway.
In order for you to use the [IMG] tags to attach a picture to your thread - you need to have that image hosted somewhere on the internet that allows linking. www.cardomain.com is a good place to host car pictures if you don't know where else to put them.
Using your own hard drive to link from will not work.
Old Nov 16, 2003 | 06:40 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The other way to post an image is to use the "Attach File" just above the "Submit Reply" Button on the bottom of your post. Do this by hitting the "browse" button and then selecting the particular jpg/bmp/etc from your HD.
There is a limit to it's size, but it does work quite well.
PS: 3.1EyeCandy is correct, you shouldn't do "tests" like that. If you need help, try a 'search' first (bet it's been asked before), or just ask.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
