Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Logged in as wrong member...
Old Jul 28, 2005 | 10:18 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
I ended up posting on the tech board as another member (I'm using his 'puter). Any way to fix that or do I just get 50 lashes and an *** beating from him?
Old Jul 29, 2005 | 12:04 AM
JT's Avatar
JT
Community Administrator
If someone had direct access to the mysql database, it could be fixed easily with a digit change. However, likely, anything sort of that can't be done to resolve it unless you have a moderator delete the post and you repost under the correct username. i don't recall any admin/moderator tool to make such a change. i think working inside the mysql database would be the only way to make the change, which i'm not sure the likelihood of someone doing that for your case.
Old Jul 29, 2005 | 10:05 AM
Damn. Oh well, worth a shot I guess. Thanks!
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
