Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Uploading pictures
Old Apr 1, 2006 | 10:52 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
this new we site is by far worse than the last. it wont let me upload a picture twice. Is there a more user friendly site for third gen owners.
learning something new is great. having to learn the same thing over again because some nerd wants to modify it slightly is a waste of my time. the site should have never been taken down and modified before they tested it and worked the bugs out.
I can not be the only one
Old Apr 1, 2006 | 11:22 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
The site won't let you upload the same picture more than once because that is a waste of space. With the old software, people would upload the same pictures over and over, using more and more space on the server. If you want to post pics, you can upload them to your own space and link them.
Also, in the User CP, at the bottom left you'll find a link for Attachments. Here you can manage all the files you have uploaded and link from there if you wish.
Since this doesn't have to do with Appearance and Detailing, I will move your comment to the appropriate board.
Old Apr 1, 2006 | 12:26 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
We'd much prefer if you guys linked pictures. Attatching will only take up space on the site.
Old Apr 15, 2006 | 06:35 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
every time i try to link to an old attachment it does not show the pic or the thumbnail. instead it shows a link. like this:
why does it not show the pic like when you link from other sites. i included the img brackets around the image.
maybe i'm missing something?
thanks
anthony
Old Apr 15, 2006 | 06:50 PM
JT's Avatar
JT
Community Administrator
thanks
anthony
It does not show a thumbnail because you are not using the Attachment feature in the post. Instead, you are simply "hot linking".
And the reason why it appears as a link, instead of a picture, is because the IMG tag does not work because of the format of the URL. Notice in your example, the end of the URL (?d=1143357199). The image tag does not like a link that does not end with a common image extension, such as .jpg
Notice if I drop off the ?d=1143357199 part of the URL, and then try to use the image tag, it works:
Old Apr 15, 2006 | 08:36 PM
@ZZKKER's Avatar
thanks jt. that helps out a bunch.
thanks
anthony
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
