Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Another search issue??
Old Apr 16, 2006 | 08:37 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Don't know if this was already mentioned, but search is not working when searching for more than one word. Instead of searching for the first word AND second word in posts, it is searching for the first word OR second word.
For example, search "maui blue". You get threads with the mention of blue but the word maui is not to be found in the thread. Its making it real diffilcult to find things.
Old Apr 16, 2006 | 08:52 PM
JT's Avatar
JT
Community Administrator
Actually, it does. It is just the fact that the word "blue" is so common, you're getting results for simply "blue". It is not narrowing it down to only posts that contain "maui" and "blue", but instead, any post that contains "blue" or "maui".
Old Apr 16, 2006 | 09:18 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Must be a bad search algorithm then, because it shouldn't matter how common a word is. Both words should be in each thread that search pulls or at least thats how I always remember it being.
I get this post when searching maui blue but maui is not in the thread:
https://www.thirdgen.org/forums/tech...2Bmaui+%2Bblue
Is there at least a way to enable searches such as "+maui +blue" to get both results in every thread? My recent searches have yield 9,999 results with no answers.
Anyone else having this problem?
Old Apr 16, 2006 | 09:25 PM
JT's Avatar
JT
No. My point was that with as common of a word as "blue" is, you are going to get a lot of results for that word, hence, any results for "maui" may be lost in all those results. I stated this because you first indicated that maui was no where to be found. It is there, but with the amount of posts with blue, it is going to make any maui posts harder to find.
I agree that it needs to be worked on. But I cannot do it.
Old Apr 17, 2006 | 08:49 AM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
me too post
"shift light rev limiter schematic" search results = 10000. It seems a thead only needs one of those words to be a hit, is there a way to search for posts/threads containing all search words? the second hit that comes up this morning is about a guy whose horn doesnt work.
thanks
Andy
Old Apr 17, 2006 | 05:33 PM
JT's Avatar
JT
After a small discussion, Jason turned on the boolean searches, which should aid in these searching issues. However, due to the load that search puts on the server due to the size of the database, some search restrictions had to be turned back on.
Old Apr 17, 2006 | 07:09 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Thanks, thats much better
Eric2ndGen
Nov 5, 2015 01:51 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
WIzmo
Aug 30, 2015 02:30 PM
Warlocksirix
Aug 29, 2015 11:36 AM
beast94
Aug 20, 2015 06:44 AM
