Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
TGO keeps logging me off
Old Jul 26, 2006 | 12:34 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
It seems as if I'm inactive for more than a couple of minutes, TGO automatically logs me off, and I need to relog in. It's very annoying. Is there anyway to fix this? I already tried looking in the options.
Thanks!
Bill
Old Jul 26, 2006 | 01:58 PM
JT's Avatar
JT
Community Administrator
As with most other vB based boards I've seen, there is a inactivity timeout that is used to determine if the user is active or not. After 15 minutes have passed with no activity from your account, all posts dated prior to your last active time will be marked as read and all future posts will be marked as new. You will then be shown as offline.
Are you using the Remember Me option when you sign on? You must place a check in the box for that option. If not, after those 15 minutes have passed of inacitivy, you will be signed off and you will need to use your user name and password to sign back in. If you place a check in the Remember Me option, you will not need to use your user name and password to sign back in, unless your browser's cookie is corrupt.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Johnny*G
Oct 20, 2015 12:37 PM
Linson
Sep 21, 2015 01:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
