Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
reply - no sig, quick reply - sig
Old Aug 19, 2006 | 01:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was just wondering, my default is such that a reply does not show my sig, which I like, but if I quick reply it shows the sig.
Is there a way to change that setting so it defaults to not showing the sig on both? I couldn't find a setting for that, it seems strange to have the defaults be "no show" and "show" respectively?
Old Aug 19, 2006 | 03:02 AM
JT's Avatar
JT
Community Administrator
What happened is that I had slightly altered that. It was something Dirk implemented on this board some time ago under the older vB 2.x software (which did not have a quick reply feature), so I followed the same direction and applied it to this newer software. When a member replies to a thread using the normal reply feature, the show signature option is unchecked by default. When a member creates a new thread, the show signature is checked by default provided that the member has a signature.
The problem is that with Quick Reply feature I've been unable to successfully do the same thing. I'd like to change it, but because I couldn't successfully at first, it sort of got brushed off to get replaced by other things.
Old Aug 19, 2006 | 10:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
ok, I'll just look for the checkmark then. Thanks!
F-body-fan
Jan 12, 2023 01:49 PM
Lbibb
May 5, 2016 12:00 AM
mattcanty
Oct 12, 2015 11:08 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
