Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
my cardomian help please?
Old Nov 7, 2006 | 12:36 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
where did you get your url for it and how do you put it in your sig? also how do you change your name
Old Nov 7, 2006 | 01:40 PM
JT's Avatar
JT
Community Administrator
To change your name (presumably your user name here), you can contact me. Only Admins can change user names.
As far as car domain, I would guess you right-click on the image and copy the URL and then post it in your signature inside the
Code:
[img][/img]
tag.
Be warned that using car domain to host images (hot linking) is flaky. Many websites don't like (or allow) hot linking due to bandwidth usage it consumes when it's abused.
Instead, you can upload a signature image to TGO's server. Go to UserCP and click on Edit Signature. The following size restrictions apply:
Max width 500 pixels
Max height 100 pixels
Max filesize 20000 bytes
Old Nov 7, 2006 | 01:42 PM
Axle/Gears: G92
ok thank you jt
Old Nov 7, 2006 | 02:15 PM
Axle/Gears: G92
OK ANOTHER QUESTION how do i put the link to my page in sig?
Old Nov 7, 2006 | 02:34 PM
JT's Avatar
JT
Example for simple text link - omit the space between [ and U:
Code:
[ URL="https://www.thirdgen.org"]TGO[/URL]
ShiftyCapone
Jun 10, 2004 08:41 AM
