Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Tech Article is BAD
Old Mar 25, 2007 | 11:53 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Tech Article is BAD
In your tech article section under miscellaneous you have an article titled:
Opinion: What Everyone Should Know.
I don't know the person that wrote this article but I can tell you that a lot of what he says is just wrong. You need to remove this article from the site so some newbies don't take it as fact.
This person obviously does not know much about how all the parts of an engine truly work together and how each affects the other and how a modification on a 305 does not act the same on a 383.
Old Mar 25, 2007 | 01:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Tech Article is BAD
That article was written about 10 years ago. Its a little dated, but I wouldnt call the whole thing bad.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
okfoz
Sep 17, 2015 10:30 AM
scottmoyer
Sep 7, 2015 07:06 PM
Street Lethal
Sep 7, 2015 01:09 PM
Amillionoh7
Sep 5, 2015 11:44 PM
