Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Can't access thirdgen.org from home!
Old Jun 18, 2007 | 09:12 PM
Naga1337's Avatar
Hi, I can't access thirdgen.org from either of my two houses. I try to connect, but Firefox keeps telling me that the connection is timing out. All other web pages work fine. To connect to thirdgen.org, I need to be either at work, or use a proxy (like I am now.) Can an administrator perhaps help me with this situation? It's really bothering me. My E-mail is naga at majbuzz dot com, if you want to help me via E-mail. Thanks MUCH for any help.
Old Jun 18, 2007 | 09:31 PM
JT's Avatar
JT
Community Administrator
Re: Can't access thirdgen.org from home!
This likely is a DNS issue. Your ISP, or maybe your computer, is not resolving ThirdGen.org to it's new IP address (what DNS does). Sometimes DNS changes take a few days to populate. You could try changing the servers your modem or computer uses for DNS, or perhaps wait a bit longer. Since it appears to me the old TGO server is not up, if your ISP is still using an old DNS record for TGO, that likely is why you're seeing the timed out connection.
Old Jun 18, 2007 | 10:11 PM
Naga1337's Avatar
Okay. Thanks. I guess I'll just wait a few days and use the proxy until this clears up.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
ironbmt
Sep 27, 2015 06:00 AM
