Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
access denied?
Old Jan 15, 2008 | 09:26 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
access denied?
i wanted to go to my bookmark where there was info on making the 10 bolt beefier and it says "access denied". Why?
Old Jan 15, 2008 | 10:05 PM
JT's Avatar
JT
Community Administrator
Re: access denied?
Please give me the direct URL (web address) so I can review.
Old Jan 15, 2008 | 10:23 PM
JT's Avatar
JT
Re: access denied?
The logs show you're accessing this one:
https://www.thirdgen.org/beefinguprear
Next question is, can you view other technical articles? Try viewing this article:
https://www.thirdgen.org/vats_passkey_system
Old Jan 16, 2008 | 02:43 PM
ryan91rs's Avatar
Transmission: 4L60
Re: access denied?
nope says the same thing. What's going on?
Old Jan 16, 2008 | 03:13 PM
JT's Avatar
JT
Re: access denied?
I will look into it. This is the first time this been reported. I have some ideas.
BTW, in case it isn't known or obvious, this isn't a personal issue. There is going to be more users that are likely seeing the same error.
Thanks.
Old Jan 16, 2008 | 05:39 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: access denied?
I can access both articles
Old Jan 16, 2008 | 05:50 PM
JT's Avatar
JT
Re: access denied?
I think I found and resolved the issue. If not, let me know.
Old Jan 17, 2008 | 05:20 PM
ryan91rs's Avatar
Transmission: 4L60
Re: access denied?
its working now but im not at the computer i usually use. will let you know
blackz281le
Jan 11, 2016 07:51 AM
shanelique22
Sep 24, 2015 06:30 PM
CatmanFS
Sep 19, 2015 09:00 AM
