Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Trouble------------>
Old Sep 25, 2008 | 04:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I Know I said I would not post in here cause I "make to many waves" But TGO has a pretty significant issue to anyone hitting the main message board page. Every link leads back to the TGO main page unless the user logs in........... If you don't log in - you don't see ANY of tis site other than the main page.
The pop - up adds are also showing up in strange places. This has just happened while I was logged in and writing this thread.
Good Luck !
Last edited by John in RI; Sep 25, 2008 at 04:31 PM. Reason: added "message board"
Old Sep 25, 2008 | 05:19 PM
JT's Avatar
JT
Community Administrator
Re: Trouble------------>
Fixed. Someone made a change to a script that doesn't appear to be working as intended. I removed and reported it.
And if there is any true "pop-up" ads, please provide a screen capture so I can check with Advertising to match up the ad.
