Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Can't get my sig pic to show.
Old Nov 17, 2008 | 09:49 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I set up a small picture and some text in my User CP.. It shows there.
When I enter a message I check off Show your Signature, but it never shows up when the message appears.. I did a search for this type of problem, but I cant' seem to find any fixes...
What am I doing wrong?
EDIT.... Hmm... Now it's showing up... No need to reply to this message --
Old Nov 17, 2008 | 09:52 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Can't get my sig pic to show.
Hey, nice sig pic, how did you do it?
Old Nov 17, 2008 | 10:05 PM
JT's Avatar
JT
Community Administrator
Jim, as you may recall since you are senior member, whenever you respond to a thread, you will need to place a checkmark in the box of "Show your signature", which is under the "Additional Options" - which is below the area you type in your message when you're using the full reply form.
Whenever you create a new thread, by default, that checkmark is already in the box of "Show your signature".
This was something Dirk setup long ago to help minimize repeated use of one's signature in the same thread. We've kept that logic.
I went through a few of your past posts, such as in the History forum, and the checkmark wasn't there.
Old Nov 17, 2008 | 10:10 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
ahhh so thats the reason mine doesn't show... god Im such a noob. Never noticed that little box before... lol
Old Nov 17, 2008 | 10:22 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Hi Jeremy
Old Jan 23, 2009 | 08:30 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
i can get my sig to show fine but how do i get the little pic under my info on the left of my posts to show? if its called a profile pic, i have one loaded in the user cp section but it doesnt show up under my user name on my posts
Old Jan 23, 2009 | 08:52 PM
JT's Avatar
JT
What you refer to is called an "avatar". You can edit yours here:
https://www.thirdgen.org/forums/prof...?do=editavatar
Old Jan 23, 2009 | 09:09 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
hey thanks, never knew what an avatar was.!
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
buckshot63
Sep 10, 2015 09:15 AM
gt4373
Sep 9, 2015 10:29 AM
