Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
sig photo not showing up
Old Aug 23, 2009 | 11:17 AM
zray's Avatar
it appears in the preview, but not in my posts. It's a photo hosted on photobucket, appears to meet size requirements.
seems to be working now
Z. Ray
Old Aug 23, 2009 | 01:35 PM
JT's Avatar
JT
Community Administrator
Re: sig photo not showing up
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show.
However, if you reply to a thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years.
Z. Ray
blackz281le
Jan 11, 2016 07:51 AM
Angie Coots
Sep 23, 2015 07:42 AM
Linson
Sep 21, 2015 01:08 PM
david068513
Sep 18, 2015 10:36 AM
84 TA NV
Sep 6, 2015 08:02 PM
