Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Why does the site automaticaly Log me out!
Old Sep 18, 2010 | 10:31 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
After logging in and cruise'n the threads for a while, and then it happens, automaticaly logged off. This is becoming a hassel especially in the middle of a post. Anybody know why?
Old Sep 18, 2010 | 01:39 PM
JT's Avatar
JT
Community Administrator
Re: Why does the site automaticaly Log me out!
That issue is going to be a corrupt browser cookie on your computer. This also is not an uncommon issue from time to time. And due to the way that cookies are used by your browser, you will most likely experience the issue on one site at one single time.
You will need to delete the ThirdGen.org cookie(s) and then revisit the site, log back in and make sure you select the "Remember Me" option when logging in.
I don't recommend you delete all your cookies, which is easy to do in any given browser via a few mouse-clicks, because you will then lose all cookie-based preferences stored per website as well as other automatic log ins you had with other sites. I always recommend the user singly delete the affected cookie(s), which the method for doing this varies on the browser you're using.
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
FueledSoul
Sep 30, 2015 09:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
