New Pics
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
New Pics
What's with the new pics I'm seeing,it says click here for larger size,how is that done.Please English,I'm computer illiterate and too old for new tricks!!!!!!!!
Re: New Pics
Pictures are automatically resized by your browser if they are larger than 1024pixel in width. If you want to see the full version of the image, click on the bar on top of the image to view the full version as it states. Note this feature requires javascript, and so it won't function correctly if you disallow javascript.
If you don't want the above to occur (no resizing), then:
1) Go to UserCP:
https://www.thirdgen.org/forums/usercp.php
2) Go to Edit Options:
https://www.thirdgen.org/forums/prof...do=editoptions
3) Scroll down to The Image Resizer under the Thread Display Options.
4) Enter a 0 into both Image width and Image height to disable the feature. This means that images won't be resized when you view them on the forum.
5) If you want the resizer to only resize pictures that are larger than a specific size other than the default (1024px), enter that value into the fields noted in Step 4 above.
1) Go to UserCP:
