Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
TGO comes up as garble
Old Jan 29, 2014 | 07:47 AM
okfoz's Avatar
From: Doghouse Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
About once a day I get this when I get on TGO:
Not sure if it is a virus, or what, but I refresh and it goes to normal.
FailedHTTP/1.1 200 OK
Date: Wed, 29 Jan 2014 13:44:15 GMT
Cache-Control: private
Pragma: private
Set-Cookie: bbmobileSearch_query=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/; domain=.thirdgen.org
Set-Cookie: bbmobileSearch_query=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/techboard; domain=.thirdgen.org
Set-Cookie: bbmobileSearch_query=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/techboard/; domain=.thirdgen.org
X-Cnection: close
Content-Type: text/html; charset=ISO-8859-1
Vary: Accept-Encoding
Content-Encoding: gzip
Content-Length: 36825
Connection: Keep-Alive
�����Zmslf[2w|$K.&l6Ɲ< +-`7쮄qRس=n?y>7xOo<Ow.xK%G/ JZ*թd3
]{Gq>l`ӻ0l؉TagÎ5{ƮBqhRGasgsa~+a'N0r?<2y@!6
gIT!I`WY&aqK9Ĵf
eDݦNW<R""|I~&DxY@>*\=GBC9T1aG'=%73<Y"S~20/{}!gsOlÝ};<܃ [YBnkH4$sS;t6Ny5_+sx 2dagy"dN_sWQ<,N&̎<Ksٚ"'HcB>[CIc"1٤@'1S>
N L(@Xq](s—iI?S<zd|,*4t'G ;I@g+cX9̧[}[GlÉQH;%-vκ* $[_* gY{3%~% ]d
X_,1?,-||a3T@¡1ED} 䨮N.29%LƆXg[|@Q^ܥDAnu>WP +鈪5tngt֗EA1"MY$
p0$jQ$2#biAՅڰCO,O"7%seYsYSQ#7&5K<>LNb*IWSI"1UoN1A&I9Xg.֔hS2T@ a"w,;60ӧ <xG-׽ukmqǸRtFV#C(&su= %E-#?\KnHf
>j6Jdö�":"!f4;lVĦIk$ܬA|ۚTs:%=W[Sk.Ø^ʋo&<V=0.S-#z]ʮ~b;S4jX4#m
y֊3%m8,2<mXnpja:05r^۾G@}*Nr[C;T"0Đ4/CW/E&c|bWӬ`5hFoĘba 1M.$0jr^k
mtWIJ ׽5TKˎ$0آ,4ƖJ9Y!Rb|Hx`f
g,Ӆ2z q’<R @t-忦Wl%3s=~z,J`Ȥu>e"~ݵQx; ?֑GUrnw@Enܘ/'?
=ҪG~HEA] iWk.{
dKiV2qQJne}3ZmkdYh3ʬY B0HL&޵"Ht/Anz܌H^c5P;˽=q6;% _=_dI
JxL,
U6!
}B/'s/+K\Dkk9FػeNwIU(p(qxJ"L8AsF;74DzXֻvQJ1~2 Ջ&"5ZkNE@J\.ީD(x; {zoYNGi"qhˀ;pJ.ӳ2 c#Jff=%V(#z
o؀VM>o8AFKfMwF
i#i1 ~UH8F Wh8M_?� ~lYw򚇝G܉
6D]}*|qM{ ~EoY'v땡s. .p& Y7uRI3jݫ(.hNܪz9H[qrnm'/{fz:tEYGJֈr\vE_RN-p)Co9Kbܞj"w-őn,Wx!B�-!)$o8T%٧>A
vyOJ`{K>lhD`hk4-g{{Ьs.�u
!}q)f)C|Q^H8P+zv6=@R@{-H7KQW?p\n9sQVO/11rdoLia
F?Dc?%P0«)qnbm<7F따0wH.!Y5ۥ&)j�>i*5(UF/n;S%״[pN!CE"G4@RTN_(K;`4#Y ϥϨ܉%cEC{o&(
/)̀f
&b*cLif{rFҊJ(uxw*E`o
b&dؾiq%
Ub+5,*vEJ5fX3'HCE?gP64~0@iqhc5xkj?]]ђ8Lr.{(H�~#9OZf.LyS[x >[DJOmK)uЋM8"v;Ea-أy(i5)Ȃ0pue(|_iÖS ^x75(;4gLjS&v~CƼ?/VhfyʜQOId&+\-4acɎF
h3FbdJH) d,*O,36?msA1'YC&5[MYNJ)*c5DR.K hoW4pd9d Ln`G�Y7;EL5Ot mw~m�
�x9�@[trrWYySe(`h1&:Gi06
3hAW2);;8;;p=@ӣ^Tj*r*YުZ<zU
EoVJu2ʐᛣ>QxG([x;-D>A]pV)Gc"1>䬜+�l+haF4| \'mj>PE&ͧ9vdC cw3J*H;焩b" '9쌽"\銅q48DB9C'3!JR}Qi k%B{=َb]*/!!
+wcsK&֚dչB&52�| 4oeN刣="7"s-$R
kl}쑈xmZ
'(|=*L[(;2$r}}:IqTЌO�ÕyB(Ԏ?9Vq!Օ9^ϣ7дRn 6ߝS
%Fӹ
$bgGghKsFDyh+Y;AM݄1%5O-3_@q +)>
"q] "fh/E^Iz
ʙ(.GOf[gvL"[[n7M}y噺y^}̲Ȯ{^{~[DOl/#lZ97m8^Mba_WW(llicJ3yRgb/rSAa<mf=T&g&sA KLXu)ݟ8BO(:/8?:ctWg[추Я�pz
uZlV*Ɔ'3e枑bqm/X6'o
̄S~@#&,SydL>8E`)T_1:3ǨCdbA,BQ_ku%ޑ ym*N3Q'@`¢qQG:
q 󳖁.zRpal;XgnAQX[AO3 .x:B9`sK)|R舴H@C:SF
^d&4i&j
϶f
+W-[:Q34(p"L4Sd(3ˀ_{vt FPYaNDf*+`"uX 8/Hͽ,�/)LmkDV{ANk*˘ւ+$,$B$6ϲaN:D.
S^:ΔY %RZ:k_<e
`9&֙Lr
So+@|:;ߘ`k;Su
WD~}:(.צ]mlʬDp,(Kᥧ9eʃcLo?n0(ȯ]{e][W[/ouդ.ZL6J$ށfG#S*\faJծ])X\9HDh;`>wh&kxH4'qe<$4)Pp J$#(`GA C(P=dZxy=hO}6q
wRIQ$2Aiv`py$ӆzr(EZDWRR
tf4%B룞|'{ªZds'UOfH>-}'\GǞY;aǮԒ1;g š~</C @AgQ}gi}ѽH#{N޲SWM䅤;Jp/hhqLxuG"
qȜ#Z"tJp,fd.P l߲SAMG,ѥ!0Lu5?M
fi Ļi5όFhp&dg2$Pbƕǃ2qyg'fW^c7ʯ<"45{W03I{qnYR$)Щ4axl + {E%ynd~^+?P.I|':Kz-.SneT_\D3_`h9>dl.tZ`,^Cn,,xyr<^T%|}OQYб#LӃ-*3Τ+qVHc<
19[Иݯ*<2:Z~lÞ{HϒaPE*ⰑMgr5݂Ʈvط޶$9hp1NKDĻ6'$ɐM+"Eɒ8;րm^]]]]ǫSI>sWgr/O
ntp?:%6ٮ,TҨ\4fvDF:IO׾ra)xq"MEŘ^AOvQPOX*6Ri+saP,[܌ɳK7aeG]X*ĴEHw u\le^{:3[hd!KpLa<z{E[L6a钥4֯/4!74KƬӞ$=^#*-C�) ;?lШЛG0\](Flh,Y!]@ֲSZJ~&kdwFKk7
@Ɖ*MJ*_e~F'W$f[8ܵ4MEZhs,/>c
B�Ny0P*Ͽ (A76h,ږm+xŲ抂GxY
8.\]Ү5bD>2e9a6dU�5*z+''\t=rL+ G>wGUW/_zj멣>>@̛0N2{`LnWNX٢g(
"9PV~_+ 1#,SoBQyDRBOG?ۘ'1h0߈uš3/*tL;;M zx*(2\}8
$;<m'62l ȑRFy(Z*} \3S-d̒uJ]caώrq#YBᲉ.EOݸl
Ao7ǬXTɢal >՜M:y-e/K{3)ZcQnz890Iy18~rzPfpIY[0? (4be|
pC-)/AmsGT^Z}︋*GV8
A8 /s*rX`KTJxWn93ϢÖZy=`!wk{V1_=p_܁wT�fءU`oM
0p)lYi Ţ*IM_AazhJ<Ql}(AKP᜷"1G
+A?pG),';gnsa:JHA(8"sS@(ܷ g{A\ΐ
=9CJS_O:jIN]L󌵙OkH} *FZ􅐬a7aiDCg%faq.wh,z2ǺTs%7h�AVvէ317r)oThW 5@
;5m8BׅAENwvوT^'A眛(�~;p)$,ՔK؀0 Yl<螢g;Z�4'*,BIG ep@Ż,\GKZzЎlYR)&_7?@_'~*D Ï~8ʏrEXZN~8aax?˩w.JڍE@9Ҿ{ixxzF_ʄب:.^q,G^9qL4q&)!:[,u#h%p&^7D~#vds#Maᯇ2RCwvmd鶎Ez6FZ?͟o37Q&4a~e0AJ8џ1O yrqHgМepSș&Α�UΒ Ʌ9Cbo]8L˂1YF
IllkgT۟UY.ha.(l,S{y<b=8rr{~VIm[G KcKq[uYs$4Ғ܉m#Ѩ0+s9jdtσk7`EڈF?<P?% wU]qMES 2QZÿC}w1K/䮲X
AbȻ~H+c*E0&닮v_b.M(ͮ*26RyTrS9Wͅ0=Z9s"܌'䒄Q.s?Uu< -@hKLE]<؝!v
Old Jan 29, 2014 | 08:50 AM
JT's Avatar
JT
Community Administrator
Re: TGO comes up as garble
John, are you using the mobile app? Can you provide a screen capture? What you're reporting is not something I've seen or heard about from others.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Johnny*G
Oct 20, 2015 12:37 PM
Linson
Sep 21, 2015 01:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
