Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Signature won't display
Old Feb 9, 2015 | 09:41 PM
Ymesss's Avatar
Car: 1986 Camaro Z-28
Hi there,
My signature is not displaying, I've messed around with it for a few days with no luck. It previews just fine...
Any ideas? Thanks in advance.
Old Feb 10, 2015 | 07:25 AM
JT's Avatar
JT
Community Administrator
Re: Signature won't display
Signature appeared in your post here.
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show. This is why it appeared in your example above.
However, if you reply to an existing thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
