List of fan switched PNs / Threads / Connectors
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
All these part numbers are from the manufacturer wells. I hope this helps someone.
Common sensors for the thirdgen are
SW555
SW505
SW500
SW502
They can use the PT308 or PT770 pigtail
SW555
SW505
SW500
SW502
Code:
Cooling Fan Switch Terminal No. Terminal Type Thread Size Normal State Specification SW1009 2 Male Blade Terminal M10 x 1.25 SW1010 2 Male Blade Terminal M16 x 1.5 Closed Breaks 185f ± 8 Makes 176f SW1011 1 Male Blade Terminal 3/8 x 18 Open Makes 225f ± 8 SW1012 2 Male Blade Terminal M16 x 1.5 Open Makes 209f ± 8 SW1120 2 Male Blade Terminal M16 x 1.5 Open Makes 194f ± 10% SW1121 2 Male Blade Terminal M17 x 1.30 Closed Breaks 239f ± 10% SW1122 2 Male Blade Terminal 3/8 - 19 BSPT Open Makes 221f ± 10% SW1123 2 Male Blade Terminal M16 x 1.5 Open Makes 185f ± 10% SW1422 3 Male Blade Terminal M22 x 1.5 Open Dual-Makes 174f ± 8 Makes 248f ± 8 SW1423 3 Male Blade Terminal M22 x 1.5 Open Dual-Makes 231f ± 8 Makes 259f ± 8 SW1425 2 Male Blade Terminal M16 x 1.5 SW1426 2 Male Blade Terminal M16 x 1.5 SW1428 3 Male Blade Terminal M22 x 1.5 Operating range - 83/87 SW1429 3 Male Blade Terminal M22 x 1.5 SW1431 2 Male Blade Terminal M16 x 1.5 100f -1020? - 220f -163? SW1433 2 Male Blade Terminal M16 x 1.5 Closed Breaks 209f ± 8 SW1434 2 Male Blade Terminal M16 x 1.5 SW1435 2 Male Blade Terminal M16 x 1.5 Closed Breaks 204f ± 8 SW1436 1 Male Blade Terminal M16 x 1.5 Open Makes 204f ± 8 SW1437 2 Male Blade Terminal M16 x 1.5 Closed Breaks 210f ± 8 SW1438 2 Male Blade Terminal M16 x 1.5 Open Makes 215f ± 8 SW1440 2 Male Pin Terminal M16 x 1.5 Open Makes 195f ± 8 SW1441 2 Male Blade Terminal M16 x 1.5 SW1442 2 Male Blade Terminal M16 x 1.5 Open Makes 203f ± 8 SW1443 2 Male Blade Terminal M16 x 1.5 SW1444 2 Male Blade Terminal M18 x 1.5 SW1445 2 Male Blade Terminal M14 x 1.5 SW1460 2 Female Terminal M16 x 1.5 SW1502 4 Male Blade Terminal Open Dual-Makes 229f ± 10 - Makes 210f ± 10 SW1510 4 Male Blade Terminal M22 x 1.5 Open Dual-Makes 231f ± 10 - Makes 238f ± 10 SW1515 1 Male Blade Terminal 3/8 x 18 Open Makes 211f ± 8 SW1630 1 Male Blade Terminal M10 x 1.0 SW1632 2 Male Blade Terminal M16 x 1.5 Open Makes 217f ± 8 SW1634 4 Male Blade Terminal Open/closed Closed-Breaks 250f ±8 -- Open-Makes 240f ± 8 SW1635 2 Male Blade Terminal M10 x 1.00 Open Makes 235f ± 8 SW1636 2 Male Blade Terminal M18 x 1.5 Open 95c - Close 100c SW1637 2 Male Blade Terminal M10 x 1.00 Closed Breaks 100f ± 8 SW1638 1 Male Blade Terminal M10 x 1.00 Open Makes 202f ± 8 SW1645 2 Male Blade Terminal M16 x 1.5 SW1799 2 Male Blade Terminal M10 x 1.00 Open Makes 185f Breaks 176 SW1801 2 Male Blade Terminal SW1802 2 Male Blade Terminal M14 x 1.5 Open Makes 200f Breaks 185f SW1803 2 Male Blade Terminal SW1820 2 Male Pin Terminal M22 x 1.5 Range: 95/90 SW1821 3 Male Blade Terminal M22 x 1.5 SW1822 2 Male Blade Terminal M22 x 1.5 SW1824 3 Male Blade Terminal M22 x 1.5 SW1825 3 Male Blade Terminal M22 x 1.5 SW1828 2 Male Blade Terminal M22 x 1.5 Range:96c/91c SW1829 3 Male Blade Terminal M22 x 1.5 SW1833 2 Female Terminal 5/8 x 18 SW1834 2 Female Terminal M16 x 1.5 SW1842 1 Male Blade Terminal M16 x 1.5 Closed Breaks 120f ± 8 SW1887 2 Male Blade Terminal M16 x 1.5 Open Makes 93c ± 3 SW1888 2 Male Blade Terminal M18 x 1.5 Open Makes 199f Breaks 190f SW1895 2 Male Blade Terminal M16 x 1.5 SW1902 2 Male Blade Terminal M12 x 1.5 Closed Breaks 221f Makes 210f SW1957 2 Male Blade Terminal M22 x 1.5 Open Makes 197f Breaks 188f SW1958 3 Male Pin Terminal M22 x 1.5 Open Dual-Makes 197f Breaks 188 -- Makes 222f Breaks 213f SW2021 1 Male Blade Terminal 3/8 NPT Open Makes 224f Breaks 218f SW2022 1 Male Blade Terminal 3/8 NPT Open Makes 234f Breaks 228f SW2032 1 Male Blade Terminal M21 x 1.5 SW2164 1 Male Blade Terminal M16 x 1.5 SW2378 2 Male Blade Terminal SW2379 2 Male Blade Terminal M18 x 1.5 SW2380 2 Male Blade Terminal M15 x 1.00 SW2400 2 Male Blade Terminal M16 x 1.5 SW2883 2 Male Pin Terminal M16 x 1.5 SW2902 2 Male Blade Terminal M15 x 1.00 SW3009 2 Male Blade Terminal M16 x 1.5 SW3011 3 Male Pin Terminal M14 x 1.5 Range 91/104c SW3012 3 Male Pin Terminal M14 x 1.5 Range 91/99c SW3013 SW3014 2 Male Blade Terminal SW3016 2 Male Terminal M16 x 1.5 Stamped 115° Off SW3017 2 Male Blade Terminal M16 x 1.5 SW3156 2 Male Blade Terminal M22 x 1.5 SW3157 2 Male Blade Terminal M22 x 1.5 SW3375 1 Male Blade Terminal M17 x 1.25 SW3376 2 Male Pin Terminal M22 x 1.5 SW3459 2 Male Blade Terminal ID .375-25UNF SW3696 2 Male Blade Terminal SW3721 2 Male Blade Terminal SW3729 3 Male Blade Terminal M22 x 1.5 102°/95° SW4075 2 Male Blade Terminal M22 x 1.5 95° SW4088 2 Male Blade Terminal M10 x 1.5 SW4139 2 Male Pin Terminal ID M10 x1.5 SW4244 2 Male Blade Terminal M16 x 1.5 SW4247 3 Male Pin Terminal M14 x 1.5 80°/88°c SW4248 3 Male Pin Terminal M14 x 1.5 80°/88°c SW4293 M16 x 1.5 SW4374 3 Male Blade Terminal M22 x 1.5 Open Dual-Makes 101c Breaks 93c--Makes 213c Breaks 200c SW4376 2 Male Blade Terminal M10 x 1.0 SW500 1 Recessed Post 3/8 x 18 Open Makes 230f ± 8 SW501 1 Male Bullet Terminal 3/8 x 18 Open Makes 222-239 f SW502 1 Recessed Post 3/8 x 18 Open Makes 238f ± 8 SW503 1 Male Bullet Terminal M16 x 1.5 Open Makes 208f ± 14 SW504 2 Male Blade Terminal M16 x 1.5 Open Makes 204f ± 8 SW505 1 Recessed Post 3/8 x 18 Open Makes 221f ± 8 SW506 2 Male Blade Terminal M16 x 1.5 Open Makes 194f ± 8 SW507 1 Male Bullet Terminal M16 x 1.5 Open Makes 204f ± 8 SW508 1 Blade Terminal M16 x 1.5 Open Makes 190f ± 9 SW509 3 Male Blade Terminal M22 x 1.5 1) Opens 185f Closes 203f 2) Opens 188f Closes 215f SW510 1 Male Bullet Terminal 3/8 x 18 Open Makes 210f ±10 Opens 185 SW511 1 Male Blade Terminal M16 x 1.5 Open Makes 194 ± 3 SW512 1 Blade Terminal M16 x 1.5 Closed Breaks 201f ± 8 SW513 1 Blade Terminal M16 x 1.5 Open Makes 238f ± 8 SW514 2 Male Blade Terminal 1/2 x 14 Open Makes 200f ± 10 Opens 170f SW515 1 Male Blade Terminal M16 x 1.5 Open Makes 105c ± 10 SW516 1 Blade Terminal M16 x 1.5 Open Makes 105c ± 3 Opens 98c ± 4 SW517 2 Male Blade Terminal M16 x 1.5 Closed Breaks 90c ± 3 Makes 83c ± 4 SW518 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ± 3 Breaks 83c ± 4 SW519 2 Male Blade Terminal M16 x 1.5 Open Makes 95c ± 5 Breaks 90c ± 5 SW520 1 Male Bullet Terminal M16 x 1.5 Closed Breaks 97c ± 3 Makes 92c SW521 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ± 3 Breaks 83c ± 4 SW522 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ±3 Breaks 83c ± 4 SW523 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ±3 Breaks 83c ± 4 SW524 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ±3 Breaks 83c ± 4 SW525 2 Male Blade Terminal M16 x 1.5 Open Makes 92c ± 3 Breaks 82c ±4 SW526 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ± 3 Breaks 83c ± 4 SW527 2 Male Blade Terminal M16 x 1.5 Open Makes 90c ± 3 Breaks 83c ± 4 SW528 2 Male Blade Terminal M16 x 1.5 Open Makes 105c ± 3 Breaks 98c ± 4 SW530 2 Male Blade Terminal 1/2 x 14 Open Makes 184f ± 7 Breaks 159c SW531 2 Male Blade Terminal 1/2 x 14 Open Makes 210f ± 10 Breaks 185 f SW532 2 Male Blade Terminal 1/2 x 14 Open Makes 212f ± 5 Breaks 192 f SW533 2 Male Blade Terminal M22 x 1.5 Open Makes 203f ± 5 Breaks 194f ± 5 SW535 1 Male Bullet Terminal M16 x 1.5 Closed Breaks 203f ± 6 Makes 194f ± 6 SW536 2 Male Blade Terminal M16 x 1.5 Open Makes 190f ± 6 Breaks 174f ± 6 SW539 1 Blade Terminal M16 x 1.5 Closed Breaks 206f ± 8 SW541 1 Male Bullet Terminal 1/4 x 19 Open Makes 218f ± 9 Breaks 209f ± 9 SW542 2 Male Blade Terminal M16 x 1.5 Open Makes 170f ± 8 SW543 M16 x 1.5 SW544 2 1 Male 1 Female Bullet M22 x 1.5 Open Makes 210f ± 8 SW546 M16 x 1.5 Open Makes 198f ± 9 Breaks 189f ± 9 SW547 1 Blade Terminal 3/8 x 18 Closed Breaks 122f ± 9 Makes 113f ± 9 SW548 M16 x 1.5 Closed Breaks 194f ± 9 Makes 185f ± 9 SW551 1 Blade Terminal M16 x 1.5 Closed Breaks 203f ± 9 Makes 194f ± 9 SW552 2 Male Blade Terminal M22 x 1.5 Open Makes 199f ± 8 SW553 2 Male Blade Terminal M22 x 1.5 Open Makes 217f ± 9 Breaks 208f ± 9 SW554 2 Male Blade Terminal M16 x 1.5 Open Makes 203f ± 5 Breaks 194f ± 5 SW555 1 Female Terminal 3/8 x 18 Open Makes 210f Breaks 205f SW556 2 Male Blade Terminal M22 x 1.5 Open Makes 197f-208f Breaks 177f-188f SW557 1 Blade Terminal Open Makes 212f ± 9 Breaks 203f SW560 1 Male Bullet Terminal Open Makes 198f ± 8 SW562 2 Male Blade Terminal M16 x 1.5 Open Makes 204f ± 8 SW563 2 Male Blade Terminal 3/8 x 18 Open Makes 63f ± 8 SW565 2 Male Blade Terminal M22 x 1.5 Open Makes 224f ± 6 Breaks 210f ± 6 SW566 2 Male Blade Terminal M16 x 1.5 Open Makes 190f ± 8 SW567 2 Male Blade Terminal M22 x 1.5 Open Makes 198f ± 5 Breaks 180 ± 5 SW568 2 Male Blade Terminal 1/4 x 19 Closed Breaks 147f ± 8 SW569 2 1 Male 1 Female Blade 3/8 x 18 Closed Breaks 128f ± 8 SW571 1 Male Pin Terminal Open Makes 226f ± 8 SW572 2 Male Blade Terminal M14 x 1.5 Open Makes 99c SW576 2 Male Blade Terminal M16 x 1.5 SW577 2 Male Blade Terminal Closed Breaks 174f ± 8 SW578 3 Male Pin Terminal M22 x 1.5 Open Dual-Makes 92c Breaks 82c - Makes 96c Breaks 82c SW580 13/16 x 14 unc Open Makes 228f ± 8 SW581 2 Female Pin Terminal M22 x 1.5 Closed Breaks 210f ± 8 SW583 1/2 x 14 Open Makes 224f ± 8 SW585 2 Male Blade Terminal M22 x 1.5 Open Makes 203f ± 6 Breaks 194f ± 6 SW586 2 Male Blade Terminal M22 x 1.5 Open Makes 198f ± 5 Breaks 189 ± 5 SW587 2 Male Blade Terminal M16 x 1.5 Open Makes 90c Breaks 85c SW588 2 Male Blade Terminal M22 x 1.5 Open Makes 140f ± 9 Breaks 122f ± 9 SW589 2 Male Blade Terminal M16 x 1.5 Open Makes 210f ± 8 SW590 2 Male Blade Terminal M16 x 1.5 Open Makes 185f ± 9 Breaks 176f ± 9 SW591 2 Male Blade Terminal 3/8 x 18 Open Makes 185f ± 8 SW592 2 Male Pin Terminal M16 x 1.5 Open Makes 194f Breaks 185f SW593 2 Male Blade Terminal M22 x 1.5 Open Makes 110c ± 5 Breaks 115c ± 5 SW594 2 Female Pin Terminal M22 x 1.5 Open Makes 198f ± 9 SW595 2 Male Pin Terminal Open Makes 198f ± 6 Breaks 189f ± 6 SW611 1 Male Blade Terminal M16 x 1.5 Open Makes 194f ± 9 Breaks 185f ± 9 SW648 2 Male Blade Terminal M18 x 1.5 Open Makes 216f ± 8 Breaks 206f ± 8 SW649 1 Male Blade Terminal 3/8 x 18 Open Makes 223f ± 8 SW650 3 Male Blade Terminal M22 x 1.5 Open Dual-Makes 189f ±8 Breaks 170f ±8 Makes 198f ±8 Brea SW651 2 Male Blade Terminal M16 x 1.5 SW652 1 Male Blade Terminal M16 x 1.5 Closed Breaks 197f ± 8 SW653 1 Male Blade Terminal M16 x 1.5 Closed Breaks 200f ± 8 SW740 2 Male Blade Terminal M16 x 1.5 Open Makes 216f ± 5 Breaks 206f ± 5 SW741 2 Male Pin Terminal M16 x 1.5 Closed Breaks 234f ± 5 Makes 224f ± 5 SW940 3 Male Pin Terminal M14 x 1.5 SW956 2 Male Blade Terminal M14 x 1.5 TU192 2 Male Pin Terminal M16 x 1.5 Closed Breaks 158 ± 8 Makes 137f min TU244 1 Male Blade Terminal 3/8 x 24 Open Makes 140f ± 8 TU269 2 Male Blade Terminal M16 x 1.5 Open Makes 220f ± 8 TU325 1 Male Blade Terminal M10 x 1.0 TU342 2 Male Blade Terminal M15 x 1.00 TU344 2 Male Pin Terminal M14 x 1.25 TU367 1 Male Blade Terminal M16 x 1.5
Re: List of fan switched PNs / Threads / Connectors
Updated with pigtail PNs
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
Hello,
I have a SW505 since a few time and I would like to install on my car but question for me ........ the SW505 breaks at ?????
Code:
Open Makes 221f ± 8 OK but and
SW555
SW505
SW500
SW502
SW555
SW505
SW500
SW502
Code:
