Original spark plug wires
Re: Original spark plug wires
Looks like it. I have some at home I took off of a low mile 89 and 92. I think they are the same.
Car: 1989 IROC G92 LB9 MK6
Transmission: MK6
Axle/Gears: 3.45
Thanks TTOP, I assumed so, PACKARD and being numbered. My car is not low miles so I wondered.
Packard is, or was the electrical division of GM. I haven't looked too closely lately but Packard Del-core seems to ring a bell. I'd imagine any combination of GM, AC, Delco, Packard, etc could be considered correct.
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Car: 90 Formula / T-tops
Transmission: MD8
I changed mine out in 92 cause they were not cool looking enough. Big mistake! But the do look familiar. Black and boring. The 90 degree turns look familiar as does the white lettering. I may end up finding them laying in a box somewhere. Eps ill let you know if found.
Car: 87 GTA, 84 Z28
Engine: 5.0 TPI
Related question:
When I changed the wires on my 87 GTA, it had aftermarket plug wires but the coil wire said 8mm Packard.
From this I assumed all the original wires 8 mm.
The picture the OP has says 7mm.
Were original Packards 7mm or 8mm?
Or is it just the coil wire that is 8mm?
Related question:
Donald Croes
Mar 14, 2016 02:34 PM
