Original spark plug wires
Old Apr 7, 2016 | 01:39 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Is this an original spark plug wire for 1991? Thanks in advance
Old Apr 7, 2016 | 01:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Original spark plug wires
Looks like it. I have some at home I took off of a low mile 89 and 92. I think they are the same.
Old Apr 7, 2016 | 02:02 PM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Thanks TTOP, I assumed so, PACKARD and being numbered. My car is not low miles so I wondered.
Old Apr 7, 2016 | 02:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
My 85 WS6 has the numbered Packard wires. 56k miles
Old Apr 7, 2016 | 04:40 PM
Drew's Avatar
Packard is, or was the electrical division of GM. I haven't looked too closely lately but Packard Del-core seems to ring a bell. I'd imagine any combination of GM, AC, Delco, Packard, etc could be considered correct.
Old Apr 7, 2016 | 07:45 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
(should have grabbed those)
Old Apr 7, 2016 | 10:23 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I changed mine out in 92 cause they were not cool looking enough. Big mistake! But the do look familiar. Black and boring. The 90 degree turns look familiar as does the white lettering. I may end up finding them laying in a box somewhere. Eps ill let you know if found.
Old Apr 7, 2016 | 10:25 PM
Roadrunner77Z's Avatar
Car: 87 GTA, 84 Z28
Engine: 5.0 TPI
Related question:
When I changed the wires on my 87 GTA, it had aftermarket plug wires but the coil wire said 8mm Packard.
From this I assumed all the original wires 8 mm.
The picture the OP has says 7mm.
Were original Packards 7mm or 8mm?
Or is it just the coil wire that is 8mm?
Old Apr 7, 2016 | 10:33 PM
LiquidBlue's Avatar
Transmission: MD8
I was thinking 7mm sounds right. I wanted thicker wires cause they seemed cooler
Old Apr 8, 2016 | 05:40 AM
TTOP350's Avatar
Originally Posted by Roadrunner77Z
Related question:
I think they were all the same size. They may have used the #8 plug wire to make the coil wire.
Rumblebee
Apr 11, 2016 10:47 AM
86camaroZ
Apr 7, 2016 06:26 AM
1982firebird7
Apr 2, 2016 09:13 AM
Donald Croes
Mar 14, 2016 02:34 PM
armybyrd
Mar 8, 2016 09:18 PM
