Fasteddis Turbo 3.1/3100 Hybrid
Old Sep 6, 2016 | 08:43 PM
  #1751
project89's Avatar
Re: Fasteddis Turbo 3.1/3100 Hybrid
i would go atleast .025, loose is good
Old Sep 7, 2016 | 05:10 AM
  #1752
fasteddi's Avatar
Axle/Gears: Strange S60 4:10s
Ok ill double check a few things. I was always tought .001 for every inch of the diameter... ie. Our 2.xx journals need .002xx of preferred clearence.
I hope i dont regret these mls head gaskets... no more fuse to blow and save me.
Old Sep 7, 2016 | 01:22 PM
  #1753
project89's Avatar
is it me or do those gaskets hang into the bore?
Old Sep 7, 2016 | 01:46 PM
  #1754
fasteddi's Avatar
It must have been the picture that makes it look like that trust me they're are not inside the bore
Old Sep 9, 2016 | 02:42 PM
  #1755
fasteddi's Avatar
Started playing arround with the cage today. Going to be fun making some of those welded alot worse trust me..lol
The only things that all welded out is the main hoop mounting plates. I wasent going to do that in the car. A bit tight on the outter edge.
Old Sep 13, 2016 | 04:23 PM
  #1756
fasteddi's Avatar
Im currently missing drag week and its finally came to my home area... norwalk ohio.
But im still dealing with my moms issues and alot of other things.
Updates on the car. I finished tossing the other side of shocks and struts on. The block is ready to assemble. I just need to get my pistons and toss all of that in there.
Ill be using my delta 270 cam again as its a good turbo cam.
Im also doing a complete overhaul on my trans. It will be built as much as you can with new hardened and better parts all arround.
I have about every last part to do what i want this winter so my car is a solid 11.50 bracket car that is actually reliable and not hacked together.
Optium red top bat
New 35000 gwv trans cooler.
Braded 6an trans lines
Braded 10an and 4 an oil turbo lines
PTC billet front nissian core 9.5" custom converter
TH350 tubular x member/ adjustable tq arm with d shaft loop
Lakewood struts and shocks
Boost smart 38 W gate
Locar dipstick
All new wiring though out the car for the add ones with a new switch panel with breakers.
electric water pump
arp head studs
cosmic mls head gaskets
COMP Cams Pro Magnum lifters
6/8pt roll cage.
New pistons, moly rings, clevite bearings all arround, timing set, you name it
So I have alot of work in front of me but im tired of having a hacked together drag car.
Right now my spare time is spent welding in the roll cage as i want to get it nhra track cert next spring. Im tig welding it all which is pretty easy but alot of welding when you have to weld in the 6x6 plates.
Old Sep 15, 2016 | 01:32 PM
  #1757
fasteddi's Avatar
Got my turbosmart bov today. I will be happy to finally have a very good quality bov and wastegate that I dont have to worrie about for once.
I saw this that is very cool. A sensor cap for the turbosmart wastegate. It will give a feed back position of the wastegate itself by a 0-5vts feed back. I'm not buying on but the idea of it is definitly cool. I have my solenoid that does its thing so I can see the command but to see real live feed back from a wastegate position would be nice.
http://www.turbosmartdirect.com/Product-Categories/Sensor-Caps/
Old Sep 15, 2016 | 04:13 PM
  #1758
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
She's come a long way since I last seen the setup.
It's you... it's always you...
Old Sep 15, 2016 | 05:26 PM
  #1759
1slow8t3's Avatar
Car: 83 v6 firebird
Engine: None right now
Transmission: none right now
Axle/Gears: 3.08 one tire fire
You missed out on some good racing! 350 cars, lots of 8-9 second cars and a turbo 3400 cavalier racing in it too!
You still have tomorrow to see the last day back in Columbus!
Hope that your mom is doing alright.
Old Sep 15, 2016 | 06:54 PM
  #1760
fasteddi's Avatar
She is in hospice right now. It's terrible and they only gave her a few days left. Drag week I'm sure we'll come around my area again. Tough times for our family right now. Mom just turned 59 last month.
Anybody get any pictures of that turbo 3400?
Old Sep 15, 2016 | 06:56 PM
  #1761
fasteddi's Avatar
Thanks. I'm finally trying to be reliable and fast instead of cheep and fast..
Old Sep 15, 2016 | 07:24 PM
  #1762
I'm not going to comment on hospitals, doctors. what they put their patients through, and then finally hospice. What I will say Mark is whether you believe or not, your mother is in God's hands, and everything is going to be okay. Believe me it will. If and when that moment comes, remember that she is right there beside you, and in a blink of an eye you will one day be there with her. You will most certainly see her again, but while you are here keep honoring her by living your life how she taught you, and pass on everything she has given you to your kids. It's going to hurt Mark when it finally happens, it feels like a piece of your heart is being ripped out of your chest, be strong, and remember that she is no longer suffering, and her eternal sole is back where it is before coming here 59 years ago. Always remember that she stands with God, all of us will one day.
God bless her.
Old Sep 16, 2016 | 05:45 AM
  #1763
fasteddi's Avatar
God bless her.
Thanks Rob, and I truly mean it. And thanks everyone who has said such powerful things though this time for our family. It truly means alot when our car/racing family, some we have never even met, take time out to say a few words to help us all. It means alot. Thanks everyone.
Old Sep 16, 2016 | 04:48 PM
  #1764
fasteddi's Avatar
I sorta did a thing.
I came into a deal where if I set up a hughes Canopy at every race next year, contingent that I at least go to 10, also display the hughes stickers on my car where it's visible and a few other things I got a transmission at cost. I got this hughes 850hp rated trans with a 9 inch tail reverse full manual valve body and also a transbrake which I won't use next year for a steal. I have a few other sponsors for me such as Royal Purple and T and T Graphics out of Bellevue Ohio. But I cannot pass up on one from this company. One for my good friends became a authorized dealer and helped me get my foot in the door
Sometimes you will be amazed on who will sponsor you when you have a car that has a lot of attention. Most of the ones I've never tried to get are usually 10 to 20% over cost but this is the first time I've ever gotten something at cost. It is a first for me and since it's part of Fasteddi boosted Specialties it is tax exempt
The next spring we will be running this transmissions and having the other one as a spare although I doubt I will need it
Old Sep 16, 2016 | 09:30 PM
  #1765
project89's Avatar
nice job , i might be interested in ur old th350 if u want to sell it , ill be needing a spare next season. i really dont expect a th350 to live long behind my motor when its turned up and having a spare to rotate in while i rebuild the other would deffinatly be a huge +
when i ran the 700 in my v6 car i did the same thing , blow one up put in the backup and rebuild the original while the spare as in the car , then id run the spare till it started t slip then swap in the one i just rebuilt etc etc
Old Sep 17, 2016 | 07:53 AM
  #1766
fasteddi's Avatar
Im always open to sell things bud. I will say I've never had a issue with the th350 behind my engine. These trans are definitly nice behind any car under 600hp and not using a brake. The other one I have i rebuilt last winter still works great. But when I had a chance to get a new professionally built one for half what they charge list, I just couldn't pass it up.
This one has a brake which I'd love to use but it's so hard to budget 200p-2500 for a direct swap 8.8 12 bolt or 9 inch. Id like to build a 8.8 swap but havent got there yet. I know I'm on borrowed time with the 10 bolt. The only thing I think saving me is my 3.23 gears, it's got every thing you can get for it (including c clip elims) and the fact I rarely pull anything under 1.70 60 foot. Although I did pull alot of 1.64-68s in a row for a whole 3 day weekend. About 15 passes and it didn't cause me too much concern.
Old Sep 17, 2016 | 09:22 AM
  #1767
1slow8t3's Avatar
Car: 83 v6 firebird
Here is some info on the cavalier. Unfortunately he had issues all week with it and only had one 12 second pass that I know of for the week.
http://www.v6z24.com/jbodyforum/taking-the-z24-on-drag-week-2016-and-have-some-questions-t138977.html
Old Sep 17, 2016 | 01:20 PM
  #1768
fasteddi's Avatar
That is pretty damn cool it's nice to see a setup sorta like mine. I like it alot. Thanks for the link.
Old Sep 17, 2016 | 08:13 PM
  #1769
project89's Avatar
mark whats the chabnce u happen to have a set of good vacum lines the hard plastic ones for a 3400
i need the pcv and breather tubes both of miner are cracked and very brittle
Old Sep 18, 2016 | 06:28 AM
  #1770
fasteddi's Avatar
I will look today. Not sure if I do or now.
Old Sep 18, 2016 | 04:10 PM
  #1771
fasteddi's Avatar
NO extra set bud. Sorry.
Old Sep 20, 2016 | 11:27 AM
  #1772
Wafflestomp's Avatar
Car: 1987 Camaro, 1984 Camaro Berlinetta
Engine: cammed 2.8, turbo 3.1 hybrid
Axle/Gears: 3.42 one tire fire
Im sorry about your mom man I my mom just passed a few weeks ago she had advanced stage lung cancer I know what ur going through
Old Sep 20, 2016 | 04:26 PM
  #1773
fasteddi's Avatar
My mom has the same thing. Stage 4 lung cancer. Its spread to her joints and brain. The brain is what untimenty has caused her to go into hospice. Its sad and when she passes it will be a good thing as she wont be suffering anymore and in a better place. She has been suffering so much lately. No one deserves that.
Shes had a hip replacement, a surgery to scrape her tibula, and many many radiations and stints with chemo. Such a terrible disease.
Old Sep 28, 2016 | 03:41 PM
  #1774
fasteddi's Avatar
Well on sept 20th my mom passed away from stage 4 lung cancer. It was a long week and weekend to say the least. But shes resting now and not suffering anymore which helps us all.
Last week while i was back arround my home town i droped off some rods with pistons on them to level performance. I had them look to see if the rods were in ok shape or not... turns out 3 of the 6 were slightly bent. I dont know how long they were like that but you could barly see it, so it wasent bent alot. But when I think of the abuse they have taken i guess it happends, exspecially when i was shifting at 6500-6700 all day long at the track when I went.
Considering.....
"12515767 --- Connecting Rod
This forged steel connecting rod is used in all V6/60o Chevrolet engines. It has a 5.700" center-to-center length.
Technical Notes: Production rods are suitable for off-highway V6/600 engines which operate at a maximum engine speed of 7000 RPM...."
I need to start keeping my rpms down and i would imagine if I did bend them myself the 12.5:1 compression with a load of boost is a cause for them to bend a little...
Old Sep 28, 2016 | 04:24 PM
  #1775
Shaun41178's Avatar
Gm rates them to 7k rpm but also I read at one time that it was 400 hp too.
I made 370 whp and 470 tq and never shifted over 6k rpm with stock compression. 3 rods bent. I am guessing the tq is what bent mine and not rpm
Old Sep 29, 2016 | 08:14 AM
  #1776
fasteddi's Avatar
I had the Machine Shop friend also look at the low compression motor that I ran for three years. Those rods were fine straight as an arrow. I'm assuming that the other bent set got bent because of the high compression engine along with boost. I will say though stock rods do handle a lot. It's amazing that that 3 year old motor lasted as long as it did. Easily 250 passes on that set up.
Old Sep 29, 2016 | 09:49 AM
  #1777
fasteddi's Avatar
I started welding my rear support plates today I had a few minutes to spare so I layed down a few quick beads. I know they could look better but I didn't want walk the cup and only had 3/32 mild filler.
It's going to take me alot of hrs to finish welding up this cage.
Old Sep 29, 2016 | 11:10 AM
  #1778
project89's Avatar
u should really mig weld those plates down or do u only have a flux core mig?
theres alot of undercut in those welds id make a econd pass on them and wait till u got some thicker filler wire before tig welding the rest
Old Sep 29, 2016 | 02:06 PM
  #1779
fasteddi's Avatar
I planned to 2 pass everything. It took me like 15 min to weld a whole 6 inch plate down with the first pass.... that's 24 inches of weld
But I won't mig weld it. I just don't trust a mig weld like a tig because I've done alot of bend tests in my days on pipe. And a mig will fail alot of the time unless you preheat it. Gmaw just isnt very good at penitration at the beginning of the weld. tig root weld and tig out will rarely fail because you see everything in the weld and it's so much easier to break down in the base metal. Some of that undercut you see will happen regardless of angle, speed, amps, arc gap, and fillers because of the thickness of metal compared to the fillers. I'll 2 or 3 pass it and it'll fill in nice I'm sure.
I've seen some really nice but also some down right awful mig welded cages at the track before that even had a cert.. more like a deadly weapon of you wreck then a safety decive.. lol
Old Sep 29, 2016 | 07:29 PM
  #1780
project89's Avatar
yeah i wouldnt mig the tubes but we have always migged in the plates
been doing this for many years
Old Sep 30, 2016 | 05:01 AM
  #1781
fasteddi's Avatar
I do have a MIG welder but it is an influx set up. Honestly that is my emergency repair welder because it will weld anything LOL
Old Oct 5, 2016 | 02:52 PM
  #1782
fasteddi's Avatar
Finally got the converter. Excited to finally run a custom converter. Dont get me wrong though the freakshow i used for 2 years was great for the price. It really did well. But its time to step up the game a bit and help me get those consistent 60 foots i want, and also be able to spool up the turbo faster but yet keep the converter tight up top. Im sure I will really enjoy this converter once I get to use it. Im tired of the old cheep and fast route that Ive been playing for the past 5 years.
Another great thing is the converter only has the smaller bolt pattern for the th350 so i wont have to notch out the pads and get it balanced to clear the starter like before.
Old Oct 7, 2016 | 12:28 PM
  #1783
1slow8t3's Avatar
Car: 83 v6 firebird
Did you get some connecting rods yet?
http://www.60degreev6.com/vb5/forum/non-engine-specific/buy-sell-trade/28240-ryan-falconer-carillo-rods
Old Oct 7, 2016 | 01:40 PM
  #1784
fasteddi's Avatar
I have scat 4340 forged I beam sbc rods machined to the 2 inch journal. Same friend that was playing with my bent ones... std forged dimond pistons on top of that. Then the cosmic mls std bore head gasket and arp head studs.
I know the rods aren't the best but they are rated at 600hp. Way more then what I'll make and the cost was pretty resonable. Said and done a set of 6 rods ready to roll cost 380 bucks. ..the pistons though. Outragous.....
Thanks for the link though. Hopefully someone picks them up.
Old Oct 17, 2016 | 06:11 AM
  #1785
fasteddi's Avatar
I'm in the process of building 2 motors. One being a stock rod crank hyper piston 9.6:1 comp engine. 3.4/3400.
Clearences mains at .0028-.003 even
Clearences journals at .002 even.
I like to clearence the bearings long ways and across them as well to make sure I don't need my block line bored.
Gapped top ring at .021 and middle at .026
MLS gaskets head studs...exc
This will be a boosted engine going into the blue camaro. Just some Speed pro pistons hypers. Shoot peen rods.
The 2nd engine will have dimond pistons scat forged I beam rods and stock crank. 10:1 comp Head studs mls gaskets exc. That will be going into a roller camaro I'm hopefully picking up soon. The plan is to run the trans brake transmission and a modified 8.8 rear.
Doubt it will be done by spring but the blue camaro will be and hopefully be a reliable 11.0-11.50 pro car. 2 step msd 4 plus box roll cage..exc.
Old Oct 18, 2016 | 09:38 AM
  #1786
project89's Avatar
i like the cam instalation handle , been using that style myself for years lmao
whats the deal with that rough crank journal ?
Old Oct 18, 2016 | 09:53 AM
  #1787
fasteddi's Avatar
Yea same here
The cranks smooth though, looks rough but it's fine no diviots. I had the other crank polished though for the forged engine. Nice and pretty..
Old Oct 28, 2016 | 12:06 PM
  #1788
but the blue camaro...
Treat her to a paint job Mark, she's been good to you...
Old Oct 28, 2016 | 12:07 PM
  #1789
I thought the same thing when I first seen that not even a minute ago...
Old Oct 28, 2016 | 12:23 PM
  #1790
fasteddi's Avatar
Once I'm done dumping money into the drive train suspention and engine I'll paint the poor Ole girl. Lol
Old Oct 29, 2016 | 03:52 PM
  #1791
fasteddi's Avatar
Update 6pt cage is about finished. Just finished up wiring up msd dis 4plus. Nice little box reminds me of the 6 plus I had before
Hopefully mateing the engine to trans this week. I have to grind away some of the bell of the trans for the bolts and she's ready to be dropped in.
Pics to follow shortly.
Old Oct 30, 2016 | 12:46 PM
  #1792
Pics to follow shortly? It's been almost 24 hours, where the heck are they lol?
Old Oct 31, 2016 | 05:40 AM
  #1793
fasteddi's Avatar
Oppd yea ive been doing a total remodel of my kitchen for the past few days. Litterly everything so I haven't journeyed outside in the garage for much..lol trust me pics will be up when I get a chance to go and take them.
I finished all my cabinates. Put in a a new countertop. Faucet. Sink Backsplash on the way with tile floor..exc.
My wife and I are looking to sell our 1st home that we have lived at for almost 5 years but need to do some updating first I'm excited for our next home. Yes big garage and a lift will be there..
Old Oct 31, 2016 | 03:26 PM
  #1794
C2YT's Avatar
Engine: 4.8l LS
Transmission: TH350
If you get a lift I'm coming over more often.
Hahah. Sounds like you have been busy too lately!
Old Nov 2, 2016 | 04:21 PM
  #1795
fasteddi's Avatar
Yea too busy. Then toss in 20hrs or so a week of schooling on top of 40hrs of work at the minimum, it makes for a fast week. I really need to make some time to work on the car again...before its freezing cold out. Thankfully the engines ready to toss in, all assembled exc.
Trust me my next house will have a lift. I would have one now but there is no point in pouring cement in a 30x50 poll barn when you know you are going to sell it and move in the next year or less.
I just want to finish wireing the thing. I havent wired up the dis4 plus box yet. Its so tiny and i want to find a place to put it else then on the floor next to where my ecm has been for the past 5 years....
Old Nov 21, 2016 | 06:20 AM
  #1796
fasteddi's Avatar
Update
I swore I took pics of the roll cage but obviously not.. lol I can't find them on my phone so I'll take some soon.
Haven't done much to the car but the engine is ready to toss in and I ground the new hughes trans so its ready to go in with it.
I have a tubular th350 x member with drive shaft loop and a tubular adjustable tq arm to also go into the car.
My goal is to get the engine back in by the 1st of the year so I'm not chaining my tail in the spring time
Anyone ever wire up a msd4 plus to dis ignition before? I plan to wire mine up so durring pro class I can tune a transbrake and the 2 step to limit me. And also have a retard when using n20 which hopefully I don't need to use any more having the new ptc converter unless I need to "spray, slide, and get, behind".. lol at the end of the track.
Happy early turkey day everyone!!
Old Nov 29, 2016 | 02:12 PM
  #1797
fasteddi's Avatar
The butt end is done. And I can still use my hatch shade.. lol
I'm going to take a break from that and work on the msd 4 dis box
Old Nov 29, 2016 | 04:33 PM
  #1798
fasteddi's Avatar
I just have a few welds i want to run a 3rd pass on(using 3/32 since its welding to sheet metal in some areas) Then the 4 pt is welded up and tight ready to roll. I want to weld on the gussetts for the 5pt harness and also a cross brace in the back on the main hoop.
I want to leave it as a roll bar 4(5)pt for this year. Since I dont plan on going any faster then 11.0 at a best anyways I feel much safer with this, and it it goes faster then I will add in the extra door bars at that time with swing outs. But for now running mid and high 11s i just want a roll bar and a 5pt harness for some added safety and so that I can go 11.0 legally. I would like to toss the door bars on but i need to find out exactly how low I can have them. If i can have them lower so that i dont need swing outs and so its easier to get into the car then thats fine and i may do that. I need to go over the rule book again. Its been a few months since i have and i forgot alot of the specs the nhra wants.
[IMG]https://cimg0.ibsrv.net/gimg/www.thirdgen.org-vbulletin/960
x540/80-roll2_f99ebabec73e4f3f8974aac04872bc0e8d6e1b4c.jpg[/IMG]
Old Nov 29, 2016 | 05:47 PM
  #1799
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Old Nov 30, 2016 | 06:00 AM
  #1800
fasteddi's Avatar
Thanks 6.
Definitly have to add in that door bar on the drivers side. That will make me legal to 10.00. Which that car will never see. But it would look stupid with one and not the other pass side as well. Also my helment is going to exspire. Snell 2005. Damm the money never stops flying out the door for racing.. lol
