[VT] 88 IROC PART OUT
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
88 IROC PART OUT
HAVE THE FOLLOWING PARTS FOR SALE:
-LF FENDER, GOOD SHAPE,PEELING CLEAR COAT-$35
-PAIR OF RUST FREE DOORS WITH GROUND EFFECTS, MIRRORS, POWER WINDOW MOTORS, AND GLASS(PASSENGER DOOR HAS DENT TOWARDS FRONT)-$150 FOR THE PAIR
-REAR HATCH WITH GLASS-$50
-FRONT FENDER MARKER LIGHTS-$15 PAIR
-TAILIGHT ASSEMBLIES-$30 PAIR
-FRONT PARKING LIGHTS-$30 PAIR
-"CAMARO" GRILLE WITH FOGLIGHT HOLES-$30
-REAR HINGED LICENSE PLATE BRACKET-$15
-GAS DOOR ASSY-$15
-FUEL TANK FILLER BEZEL(PARK THAT GOES AROUND FILLER NECK IN GAS DOOR)-$10
-HEADLIGHT BEZEL RINGS AND BUCKETS-$15
ALSO HAVE MISC FRONT AIR DAM/RADIATOR AREA PLASTIC PIECES
PM ME WITH NEEDS
ALSO HAVE OTHER PARTS FOR SALE HERE
INTERIOR: https://www.thirdgen.org/forums/inte...-part-out.html
DRIVETRAIN: https://www.thirdgen.org/forums/engi...-part-out.html
Re: 88 IROC PART OUT
dont have but have other parts
still have lots of parts here. Let me know what you need!
again, lots of parts here. check out the links to my interior and engine/drive train related parts that are available!
tis the season to give..me your zipcode and Ill give you a quote on parts
Do you still have the tail lights available? Someone hit the back of my 89 RS and broke the tail lights, spoiler and rear bumper cover, and the tail lights are the only functionality issue as of right now.
Zip code is 48001 Michigan
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Hi,
I have a 1988 IROC too, do you still have the:
1) Right/passenger inner fender black plastic skirt
2) Right/passenger rectangular black plastic piece in the above photo, fits under bumper
3) Right/passenger B pillar black plastic trim piece about 1 ft long that fits over weather seal
4) Left/driver side ground effect bracket. Only need the metal bracket. It has two holes that screw into the ground effect and a stud that mounts to the body.
5) Pair of sunvisor brackets
Shipping to Portland 97203.
Peter
Peter
