Ignition switch wiring help
Old Jan 14, 2017 | 11:02 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I'm trying to find what the dark green wire that plugs into the ignition switch does. It's a 86 camaro.
Old Jan 14, 2017 | 11:07 AM
Community Influencer
Re: Ignition switch wiring help
Dark green/white stripe Power to instrument panel.
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Old Jan 14, 2017 | 11:10 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
No white stripe. This is where it goes.
Old Jan 14, 2017 | 11:26 AM
Looks like the green wire is coming out of the column connector. If it is that's right rear turn signal.
Old Jan 14, 2017 | 11:33 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
From what I have read or if I look the part up that is the ignition switch.which is on top of the steering column
Old Jan 14, 2017 | 11:39 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Both turn signals work on the outside of the car. And my wiring diagram shows the right rear being dark blue
Old Jan 14, 2017 | 11:52 AM
Looks like it's a ground
Old Jan 14, 2017 | 11:59 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I could have sworn it was connected to the coolant gauge. I had everything marked and my little boy pulled off some of the tape that had the writing for what it was and lost them. So that's why I'm in the dark. I appreciate it
Old Jan 14, 2017 | 12:01 PM
You might want to ohm it , coolant temp is a small green wire too.
Old Jan 14, 2017 | 07:02 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Well I found it. I had cut all my gauge plugs off and marked the wires. Well my little boy took off the tape that had my markings. Well I found my plugs and sure enough the dark green coolant wire is tied together with the dark green wire that goes to the ignition switch
Old Jan 14, 2017 | 07:37 PM
You can push down the metal and pull them out the back. Iirc the cavities are marked.
