Mounting speedhut gauges?
Old Feb 18, 2017 | 09:26 PM
BZ83TA's Avatar
Car: 1983 Trans Am
Engine: 350 ci, Performer RPM package.
Axle/Gears: 7.5", Detroit TrueTrac, 3.73
Hi all, I recently got a set of speedhuts and am working on getting them in the car, an 83 TA.
I would like to keep the original dash trim piece and
position the gauges in the original holes. I also plan to keep the board from the original gauges but only to keep the signal light panel working.
ive considered cutting holes through the plastic that goes over the original gauges and use it to mount the new ones in the right spot, but I'm not sure I'd be able to cut the holes without destroying the panel.
For those with speehuts - did anyone mount them this way? If not, any recommendations/advice?
Excited to get these things in!!
Old Feb 18, 2017 | 10:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Mounting speedhut gauges?
Not a FB, but they are speed hut.I kept the circuit board for the signals, seat belt, e-brk & hi beam.They barely fit as is.
Not the stock bezel, as the two big gauges are smaller & the 3 smaller ones are bigger than stock units, but the arrangement, signal, warning lamps are in the stock locations.
Old Feb 18, 2017 | 11:42 PM
BZ83TA's Avatar
Car: 1983 Trans Am
That looks great!! How did you cut the new bezel so well and clean? (the signal arrows etc.)
Old Feb 19, 2017 | 12:04 AM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
looks good, i been thinking of installing speed hut gauges, had them in my regal t type. get an extra gauge cluster and trim panel to put the speed huts in thats what ill do when i get time.
Old Feb 19, 2017 | 09:28 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks.The bezel, including the arrows & windows are hand cut.
Old Feb 19, 2017 | 01:56 PM
Great looking gauges guys!
Old Feb 20, 2017 | 10:08 AM
WTR388's Avatar
Car: 87 Trans Am
Check out my LS swap thread, starting at post #20 it shows how I did it... Don't mind the horrible workmanship, I didn't have a saw of any type when I did it... Were I to do it now, it would be a better appearance, however nobody will ever see the work anyways!
https://www.thirdgen.org/forums/ltx-...-t56-swap.html
Old Feb 20, 2017 | 06:20 PM
t/aws61985's Avatar
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Those are the first set of Aftermarket gauges that I actually like.
Old Feb 20, 2017 | 08:46 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
nice work i was looking at doing the same with speed hut gages on the pontiac. did them on a buick i recently sold.
Old Feb 20, 2017 | 09:07 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
I really would like to do this at some point, too. Mainly because I'd like to run their GPS speedometer. I just have a hard time cutting up my stock parts when it's so difficult to find decent replacements around here.
Old Feb 20, 2017 | 09:19 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
yea same here but i bought a cluster last year just to get lenses in good shape, and another bezel with the switches to at my own stuff too. don't mind cutting those up for new gauges. maybe next winter i'll get to that. i bought my gauges when they were on sale they have promotion throughout the year.
Old Feb 20, 2017 | 09:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Been waiting for a sale myself.Thought presidents day was it, but no luck.I kept my OE cluster/lens/bezel intact & scored a JY piece.
Old Feb 21, 2017 | 12:36 AM
BZ83TA's Avatar
Car: 1983 Trans Am
Awesome thanks!! I might just do the exact same thing, it obviously works!
I will have to keep the original green panel in some form as well as I'm hoping to retain the signal lights.
Thanks again for pointing me to this. Super cool swap you did BTW!!!
Old Feb 21, 2017 | 04:08 PM
WTR388's Avatar
Car: 87 Trans Am
Thanks... Just do a nicer job with the piece I mounted the gauges to than I did... All I had at the time was a dremel, but now I have a full on set up going so I could do a better job this time (as well as a career change that has me doing precision fabrication of aircraft parts in the air force).
I ordered the Speedo that included the turn signals and high beam indicator.
Where in Canada are you? I recently moved from Ontario to NB.
Old Feb 22, 2017 | 07:33 PM
BZ83TA's Avatar
Car: 1983 Trans Am
For some reason I didn't think hard enough about getting the signals right in the speedo, too late now! I'm sure I can make it work.
I'm out west, in Saskatoon
Old Feb 25, 2017 | 02:22 PM
I did my Speedhut gauge swap back in 2013. Almost a step by step for a 90-92 Camaro:
https://www.thirdgen.org/forums/inte...i-made-my.html
Then a few months ago when I was redoing my interior harness I altered the wiring:
https://www.thirdgen.org/forums/memb...ml#post6076491
Installing aftermarket gauges in thirdgens, especially firebirds is easy. Head over to www.austinthirdgen.org for the wiring diagrams.
Old Feb 25, 2017 | 10:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Was gonna go that route, but decided I did'nt like their little LED sigs/hi-beam indicators.So i just kept them as stand alone pieces.
