2 wire alternator to 3 wire alternator
Old Mar 23, 2017 | 08:08 AM
Boosted357's Avatar
Car: 1985 Camaro, 2012 Malibu LTZ
Engine: 357 SBC
Transmission: 350 Turbo
Hey everyone. Hoping someone can help. I had a v6 and I am dropping in my carbed v8. But the v6 had the alternator with a 2 prong connector and my v8 has the alternator with a 3 wire connector from i believe a 92 camaro. Does anyone know how I can hook up this alternator since my wiring harness only has the 2 wires? Thanks for the help!
Old Mar 23, 2017 | 01:44 PM
Community Influencer
Re: 2 wire alternator to 3 wire alternator
You may have a si going to a cs
Old Mar 23, 2017 | 07:47 PM
You can get a conversion adapter, or make your own.
You will need a pigtail that fits the new alternator.
See attached.
http://www.wiringdepot.com/store/c/1...s-Sockets.aspx
http://www.hotrod.com/articles/alter...kyard-builder/
Attached Thumbnails 2 wire alternator to 3 wire alternator-conversion.jpg   2 wire alternator to 3 wire alternator-pigtail.jpg
Old Mar 23, 2017 | 07:57 PM
Boosted357's Avatar
Engine: 357 SBC
See attached.
Haha thank you so much i actually just found this adapter like an hour ago. This will make it much easier. Do you know if i buy this adapter what do I do with the wire from the original harness. One wire runs from firewall to connector then the other wire goes from the connector to an eyelet that mounts to the bolt on the back of the alternator. Do i still need to bolt it to that location. Or just leave it disconnected
Old Mar 23, 2017 | 10:58 PM
View the photos in the HotRod article. They show everything.
Old Mar 24, 2017 | 01:44 PM
Boosted357's Avatar
Engine: 357 SBC
OK thanks for the help!
Old Jun 5, 2018 | 02:38 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Bumping this older thread as I'm scratching my head!
Anyone have the schematic for going SI to CS? That diagram is confusing and the HR article just says to buy an adapter or make your own... with no mention of HOW.
I have the 3 pin alt I'm trying to install in my 83 with the 2 pin plug.
I did see they make adapters, but don't see the point in buying one when all I need to do is cut my 2 pin plug off & wire it on to the new alt pigtail.
When looking at the adapters I also see they offer with and without warning light. Does that mean if you DON'T have a voltage gauge and just have an idiot light dash? I assume that'd make a difference in how it's wired up?
http://www.wiringdepot.com/store/p/5...ing-Light.aspx
Attached Thumbnails 2 wire alternator to 3 wire alternator-34507528_10212734273415621_6548699093349171200_o.jpg
Old Jun 28, 2018 | 02:41 PM
funknhostile's Avatar
Did you get your wiring squared away?
Old Jun 29, 2018 | 05:30 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Sorta. I ordered the adapter WITH the resistor though not sure if that was the right move or not. I'll know soon when the motor runs.
Old Jun 29, 2018 | 05:12 PM
Let me know how it turns out. I may have some advice if you get stuck.
Old Jul 5, 2018 | 06:00 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Thanks, I appreciate it. This swap is taking me forever, keep hitting dumb road blocks like this.
So have you converted? Did you use a resistor? Do you have a gauge or just warning lights?
Old Jul 5, 2018 | 05:19 PM
I am not a fan of the single wire alt. I upgraded to a 140 amp with the oem blade connection. I like to see my gauge working and didn't want another electrical hassle like I had with the crossfire ignition.
