Spohn tubular lower A-Arms with coil spring mounts
Old Nov 22, 2017 | 07:45 PM
rs90083's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 342
Hello Everyone...
Ive been reading many posts in regards to the Spohn front lower A-Arms. Most posts are very dated with negative opinions. I'm looking into options with replacing my front A-Arms and wondering if anyone has installed the A-Arms currently being offered by Spohn on their website. They appear to be an improved/updated version. They are listed as SKU #782-F and currently on sale this week.
Any feedback would greatly be appreciated. I'm installing them on a stock 1989 Pontiac firebird formula 350.
Cheers.
Old Nov 23, 2017 | 08:35 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn tubular lower A-Arms with coil spring mounts
I don't know anyone with the new style ones yet. However, UMI sells a great set of a arms that fit great and they are also on sale this week.
Old Nov 23, 2017 | 11:47 AM
UMI Performance's Avatar
Thanks Phil! And correct, we have been making that new style for quite sometime now and have a lot of great feedback. We have punished them with both street miles and lots of autocross and road course. They are also on sale
http://umiperformance.com/catalog/in...roducts_id=103
Please let me know if you have any questions. Happy Thanksgiving!
Old Nov 23, 2017 | 06:23 PM
t/aws61985's Avatar
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I have them. They are well built. BUT they have this stupid inner spring ring that holds the spring that really limits springs you can use. You have to cut them out, to really use them. They also lower your car a bit with oem ws6 springs. My tires rub too. I have new tires so maybe that is the problem. Overall go UMI. Wish I did.
Old Nov 23, 2017 | 06:34 PM
rs90083's Avatar
Engine: 5.7 TPI
Axle/Gears: 342
Thanks for the feedback. The YouTube video online looks great but I'm going pass on buying them. Seems like there are few dated posts with the same issues you stated. I have Eibach coils and don't want to risk fitment issues and the car being too low.
Old Nov 23, 2017 | 06:43 PM
t/aws61985's Avatar
Engine: Slow ones
Ya they are not bad. But all of the parts are weird. They make a really cool torque arm but the DS loop sits low and has to be cut off and welded higher. Buy them cheap and used.
Old Nov 23, 2017 | 06:44 PM
t/aws61985's Avatar
Engine: Slow ones
looks good though.
Old Nov 23, 2017 | 07:57 PM
Charliek's Avatar
Car: 86 Z28
Engine: 283
Axle/Gears: stock
I have spohn tubular control arms with bmr springs. Didn't have to change anything to get everything lined up.
Old Nov 23, 2017 | 08:01 PM
rs90083's Avatar
Engine: 5.7 TPI
Axle/Gears: 342
Looks awesome, did you find that you car was sitting lower after installation at all? Thanks
Old Nov 23, 2017 | 08:18 PM
t/aws61985's Avatar
Engine: Slow ones
I used the moog OEM Relacement springs. They didn't fit with the rings.
Old Nov 23, 2017 | 08:54 PM
Charliek's Avatar
Car: 86 Z28
Engine: 283
Axle/Gears: stock
I did the drop on stages. I first did the lowering springs from BMR. Then added the tubular control arms. I would say that the ones from spohn did lower the car slightly more. Almost a half inch more from my eye. Not inch and a half. It's inch and a quarter drop springs. Stock ride height
1.5" drop springs from BMR with tubular control arms from spohn front and rear.
Last edited by Charliek; Nov 23, 2017 at 08:58 PM. Reason: Fixing stated dimensions
Old Nov 23, 2017 | 09:02 PM
91vertZ28's Avatar
Car: 1991 Camaro Z28 Convertible
Call them by phone and they are having a clearance on the a arms from BMR for 300ish. Saved myself money by luck. This was about 2 weeks ago. Hopefully it helps.
Old Nov 23, 2017 | 09:07 PM
91vertZ28's Avatar
Checkout the recent post i made about a drop issue though. May have to use a differeny set of front springs to even out the stance of the car. Front did drop an inch more in front:/
Old Nov 24, 2017 | 08:05 AM
Years ago when we designed the UMI arms we had Eibach's we were trying. Eibach using a slightly larger wire that still works just fine in stock but doesn't always work with aftermarket arms. They will fit with the UMI lower a-arms.
