LT1 steam pipe question
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I'm in the process of putting a 95 LT1 into an 83 Camaro. On the back of the engine is the pipe that connects the two head's and then the pipe looks to connect somewhere in the coolant system. My question is where can I connect that pipe to the coolant system? Does it matter where I connect it to the system as long as it holds pressure? Thanks for any help.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: LT1 steam pipe question
Now I'm workin' from memory here,........ but I'm pretty sure that I connected the steam pipe to a 3-way upper radiator coolant hose when I converted to LT1. My conversion was done using a Thirdgen radiator and Thirdgen duel fans. I don't remember what the upper radiator hose was made to fit originally; IIRC it might have been from an LT1 equipped Corvette. ( Please SEARCH to verify this with others to be sure ! )
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
I believe that hose goes to the reservoir bottle. I think I remember LT1 cars 93-97 have an extra nipple for that hose on the overflow bottle..
Thanks guys. I think I got it .
