neutral saftey switch wires
Car: 92 z28
Engine: 5.7
Transmission: t56 6-speed
Axle/Gears: 3:42
I am replacing my automatic with a t56 in my 92 Camaro. thanks inadvance the neutral safety switch on the automatic shifter handle has six wires. I know two are for the neutral safety switch and two are for the back up lights. Do you guys know where the other two wires go?
Re: neutral saftey switch wires
The other ones, ORN/BLK? goes to the ECM and lets it know when the car is park/neutral vs drive/reverse. It's grounded in P/N. BLK/WHT goes to ground.
Car: 92 z28
Engine: 5.7
Axle/Gears: 3:42
thanks for the diagram do I need to do anything with those two extra wires now that I am changing to t56? never did this swap with a computer car
I would do a search on the transmission forum, and read all the T56 threads from cover to cover. In my personal opinion, with them left disconnected the ECM should believe the car is in gear and control the engine accordingly.
