neutral saftey switch ?
Old Mar 30, 2006 | 02:11 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
how do i just delete it totally, if i leave it unplugged will the car still start? im upgrading to a hurst ratched shifter and no on seems to know how to wire it to the provided relay so im just going to cut it out all together thanks
Brandon
Old Mar 30, 2006 | 05:56 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
no, your car won't start if you leave it unplugged. teh shifter uses the switch to complete a circuit.
can't hurst provide a wiring diagram??????
Old Mar 30, 2006 | 07:12 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Get the diagram from B&M. I don't have a scanner or i'd supply it.
Some race tracks wont allow you to race without the switch working.
For the mean time, join the puple and yellow wires together at the shifter. That will allow the car to start.
Old Mar 31, 2006 | 02:51 AM
Car: 91 z28
well i bought the shifter for my old v8 s-10 that was a manual so it didnt have any of that to begin with, so i dont have the instructions anymore, and i havent intstalled it yet, but was just wanting to know so the car wouldnt be stuck not being able to start or drive, and the track here doesnt inspect vehicles for anything, its just like a TNT runs
Old Mar 31, 2006 | 03:04 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
B&M
I might be able to help you let me look in my room. Maybe just maybe my b&m diagram might help you.
Old Mar 31, 2006 | 03:07 AM
Car: 91 z28
pm me when you find out if you found it or not, thanks!
Old Mar 31, 2006 | 03:09 AM
ABJ88's Avatar
Engine: 5.0/5.7
s.n.s.
I found it.
Old Mar 31, 2006 | 03:22 AM
ABJ88's Avatar
Engine: 5.0/5.7
s.n.s.
The scanner didn't work but....
Old Mar 31, 2006 | 03:32 AM
ABJ88's Avatar
Engine: 5.0/5.7
S.N.S.
Do you have an email adress I can send the diagram to?
Old Mar 31, 2006 | 03:44 AM
ABJ88's Avatar
Engine: 5.0/5.7
S.N.S.
I guess you found something else.
Old Mar 31, 2006 | 05:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
On mine (a stick car) its on the pedal, but they must be connected to work. If you cut the switch out and solder them together, the starter will engage every time you put the key to "start", in gear or not.
If you are going to race the car though, most drag strips require a functional neutral safety switch. I know because I got the "I'll pass you this time, but you gotta fix it for next time" last summer, when going through tech inspection.
Old Apr 2, 2006 | 08:24 PM
Car: 91 z28
we dont get teched during TNT runs (which is all i do because i work during points season)
Old Sep 12, 2006 | 02:40 PM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
ABJ88, I know its been about 5 months ago, but I am looking for the B&M wiring diagram you were going to send Wheelsup84z. If you still have it could you email me a copy?
Old Sep 12, 2006 | 02:56 PM
ABJ88's Avatar
Engine: 5.0/5.7
PM me your email address and Ill email it to you ASAP. I tried using the email on here, but I couldn't figure out how to attach the file.
Old Sep 13, 2006 | 01:28 PM
87camz28's Avatar
Thanks ABJ88, I'll PM you today.
Old Sep 13, 2006 | 02:07 PM
ABJ88's Avatar
Engine: 5.0/5.7
No problem!
Old Sep 14, 2006 | 11:10 AM
87camz28's Avatar
Hurst Quarter Stick Diagram
Thanks for the diagram ABJ88.
I checked and the shifter I have is actually a Hurst Quarter Stick, not a B&M Pro Stick. Below is the wiring diagram that contains the Hurst switches. Hope it helps other people.
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Fronzizzle
Sep 8, 2015 12:10 PM
