1991 manual trans MOUNT
Old Mar 10, 2018 | 07:44 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
hello i need for my 3.1 firebird with a 5 speed manual a transmission mount
cant find one on the internet the v8s use a different one
maybe someone can help me thanks
Old Mar 10, 2018 | 08:20 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1991 manual trans MOUNT
That's the oddball hydraulic mount.
It would be worth your time to just change it to the standard mount and crossmember from a V8 car. The crossmember is easy enough to find in most pick a part yyards, eBay or the classifieds here on tgo
Old Mar 11, 2018 | 07:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Agreed Xs 2. An after market version is also available.
Even if you could locate that particular mount, as I recall, it was crazy expensive.
JamesC
Old Mar 11, 2018 | 08:55 AM
luca's Avatar
Car: Firebird
Engine: 3.1
thank you do you know why the v6 use a different one when the bolt holes of the trans are the same ?
is the v6 with a manual so rare?
thanks
Old Mar 11, 2018 | 10:08 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thanks
This mount also appeared in v8 cars, no idea how or why it was chosen.
My v6 car had the standard mount, granted it was an automatic stock. I kept the mount when I converted to manual years back
The manual was uncommon in these cars period, most are automatics. The manual in a firebird seems to be more uncommon that in the Camaro from what I've seen too.
Old Mar 11, 2018 | 11:25 AM
JamesC's Avatar
The following link has info on several different mounts that were used in thirdgens:
https://www.thirdgen.org/forums/hist...ss-member.html
Before choose a mount, check out the following link:
https://www.thirdgen.org/forums/tran...ml#post4649528
Aftermarket review:
https://www.thirdgen.org/forums/afte...-t5-cross.html
JamesC
Old Mar 11, 2018 | 11:53 AM
The Mount-N-of-Power was a solution for NVH. That's Noise Vibration and Harshness if you don't speak the acronym jive. The alternative was to hang a huge steel donkey D on the tail shaft of the transmission to try to eliminate some annoyance predicted by GMs engineers. HAL-9000 predicted you'd be unhappy unless they did something about it, so fancy transmission mount.
In reality, some 30 years later, the minuscule issue that the mount was designed to dampen, is probably less annoying than any number of other current rattles or vibes. Hence we can throw fancy engineering solutions like this into the History bin, and replace them with service replacements.
Old Apr 1, 2018 | 04:18 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Thank you i replaced it with a standart mount and a v8 crossmember
works fine now
Old Apr 1, 2018 | 04:20 AM
luca's Avatar
Car: Firebird
Engine: 3.1
thanks to all for your response
epsmotorsports
Jul 15, 2016 03:27 PM
kukerdan
Feb 7, 2011 10:34 PM
Aviator857
Jun 17, 2009 01:26 PM
dimented24x7
18
Jun 20, 2006 05:55 PM
kjgroen
Nov 14, 2000 11:45 AM
