Organized Drag Racing and AutocrossDrag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
MWC are great guys. I am glad I was introduced to them by another member.
Eric, Kevin and Jason are all very helpful.
Im glad i got pointed in their direction as well. I honestly didnt know what I wanted at first. So many bash the S60 because of the weight and power it possible eats up. But after talking to them about the weight... roughy 70lbs over the stock 10 bolt. And considering the pinion angle which is much better then a 12 bolt or 9 inch, they helped me decide on this rear end. And I was very happy that they didnt try to sell me more then I needed, as I was on a major budget. I know spending 2500 bucks is alot but ever hundered dollars counts.
They contacted me today to let me know the order is sent off to strange and to exspect the rear end in 2 or 3 weeks. Helps that im buying a strange brake kit from them so I dont have to send in any backing plates.
Raced yesterdy. Ran 11.682 11.672, 11.669, 60 foots were. 1.589 1.592 and 1.599. 10 bolts still taking the lashing quite well. Hopefully it stays together so i can sell it in a month and recupe some money. Lost 1st round. .006 red light. Pissssed me off perty bad but it just wasent my day. I ran a 11.672 on a 11.66 dial. The car is so easy to dial in because its consistant. Im just off on the tree still.
Time trials my Rts were, .052 and a .063 Those are not good but i was happy with them considering my Rts since I have done this V8 swap and because i know my car wont run more then 1 hund off its dial in if not dead on. Then I go out and go .006 red. Very flustrating.
Ive been racing for 15 years now and this set up is hard for me to dial in .020-.030 rts constantly. Im getting better but I feel like im a rookie all over again. Racing a turbo V6 car for the last 6 years is so much different then a V8 that pulls the tires off the ground and leaves so fast then seems slow as helll down track... Ive got to figure this puppy out and I think seat time is the only thing that will help at this time.
Someone is going to say it, might as well be me - OLD AGE, things slowing down maybe???
Seriously though - you're doing one hell of a job with your combo. (no smiley for PROUD)
Thanks in really do appreciate it. The set up has worked so well for me. I didn't think it would be this fast let alown so constant. I have a 2 step on board and a brake. I have the just in time trans button where I can adjust the shims and springs. I want to use it so bad to help me out, but I have to finish off the year with 2 more races in my current class which doesn't allow that.
Next year I do plan to run sportsman but pro as well. Pro I can have a brake and 2 step. Much harder class but I'm ready for the challenge and I can double enter the car each race so I'll have lots of seat time.
Sometimes I swear I'm getting old, because back in the day id race anything and pull a decent....050 and under light. Didn't matter what it was. 12 flat sportsman car or a ford escape that ran 18s that you had to deep stage and then go when the 3rd amber just came on....
Originally Posted by AlkyIROC
That's why us old guys like delay box racing. Start getting slow on your reaction times, add some delay into the box to compensate.
Id love to be at that point where I could use a box. Hopefully in 5 or 10 years or so the car will be at that point. I want to make the engine last one or 2 more years before a major rebuild. Then I can upgrade the motor better so it can be a 9.90-10.50 car or so. Then be a dual pro/super pro worthy car. Just takes time and I have to go though the steps as my budget allows. Thankfully I have a decent suspension set up (the butt end at least) , a 750hp worthy trans and a bulletproof rear end on its way.
Well I almost have all my parts rounded up for the fall/winter build.
2-3 weeks wait on the s60 still
I have the driveshaft from strange, the 240/246@.050 dur.. 541/.544 lift cam, Victor jr. Intake tall one, my 8 inch 4800rpm ptc converter and now a set of afr 195 competition ported cnc sbc heads on the way.
A good friend is a vendor for afr, he's been trying to convince me to buy some for a bit now. I possibly have some one who wants my old dart heads so it prompted me to look at new aluminum heads for flow and over all weight savings.
I was amazed that he got 195s on his 383 and picked up 5mph and dropped .4 in at in the 1/4 mile after switching from dart platinum 200cc heads. He runsna 11.50@117mph 383 thirdgen. I guess afr is very good at flow vs cross sectional and volume of the runners. I remember back when 220s were the only thing my friends and I would ever put on a 383. Now 195s can flow 300 cfm even at low lift. Quite amazing. Now if I was reving to 7k i would have upped to the 210s all day. Of if I couldn't have gotten the competition cnc porting I would have done the same.
After deliberation for hrs with a few vendors and close gear heads I settled on the 195s. But these are the competition porting not the street version. So they flow upwards of 300cfm at .500 he also set me up the the correct springs to run with the cam I have.
I got them for 100 bucks more then summit sells the street style heads for so I was very pleased. It should get me to my high 10 second goal and ahead a solid 60lbs. Those old school dart heads I have.. which are stock casting and iirc 15 years old, weight app. 64lbs a piece. Heavy things. The afr 195 are app. 28lbs each.
The heads are here and look like works of art. Hopefully they perform like they look. All this new stuff won't be going on the car for at least a month if not this winter.
Still waiting on the s60 first. No sense in adding any more hp without swapping that out first.
You may hear that every 2-3 weeks for awhile. Or you may get lucky
I just got a phone call with my tracking number the S60 is on its way it took a little under 3 weeks total I'm very excited to get this rear end in a few days I'll make sure update with some pictures
That's great! I know guys that have waited for 6-8 months for things that were "instock" from them.
It's a thing of beauty!! I may try to swap this puppy in this weekend since the points races are over for the year I ended up in 15th out of about 45 people I didn't make the cut for Indy by 3 round wins but I feel I did quite well this year for being a new set up.
Well no updates. Had a few personal and family issues arise. Suxs because I got the call a week ago to represent Milan dragway as a alternate for the division 3 bracket finals in indy!!! I sadly had to turn it down because I just cant swing the time off of work right now. Family comes first no matter what. I've had to travel from where i live in Ohio out to Nebraska 2 times now. That's a long haul for me.
But the fact that I earned that chance is amazing. I racked up 99 points this year. It's the first year I didn't mess with the car really and tired my best to do well. Only missing one race.
I have a feeling next year will be even better.
I plan to race 1 or 2 more times this year for fun when I can.
I still have alot of stuff to do to the car this fall and winter. The s60 is waiting for me, the afr heads, the ptc converter, the Victor jr intake, and xe284 cam as well. Hopefully those things take the car from a 11.60 car to a 10.90 car as I plan to double enter alot more next year and run spt and pro.
The ole 10 bolt is out. took about a hr to remove it and i got the s60 ready to toss in along with the head swap. Figure i may as well do a bit of racing with them before winter.
Im also tossing on the afr heads and the victor jr intake i have. As you can see the old darts weighed about 57lbs each and the new afrs 27lbs each. So at the minumum im saving a good 60lbs up front and hopefully adding detination resistance with the aluminum heads. Hope to have it all buttoned up rear end and all monday or tuesday afternoon so i can race it next weekend.
I just need head gaskets still. .027 to be exact as the piston is .013 below the deck so I want to aim for the perfect .040 quench if i can. May as well get mls gaskets so i dont have to worrie about getting new ones evertime.
Well the s60 is almost in. Just need to attach the tq arm. The drag bar. Then hook up the brake lines and bleed them. So far this rear end was a cake walk to install. The driveshaft I got from strange was a easy fit.
Going to finish it up after work and also finish up the head swap.
I have the drag version so it's not nearly as heavy as I thought it would be. About 30lbs more then the 10 bolt I took out. Helps I have a race spool and axles.
Strange Engineering Make some NICE stuff !! they are about 45 minutes from my home they have great quality, fast service , offer Big discounts for current military & Veterans I have slammed insane 4700 RPM Nitrous Clutch Dumps at my Strange 12 bolt launches like a champ every time
I still have to finish the rear end up and beat the crap outta the inner fenders as before i had about 1/2 inch of clearance back there and now i have about 1/8 a inch so i need to massage it a bit to fit the 10 inch tires in there but its coming along well.
That #1 plug wire looks out of place. But it won't burn on the headers.
oh yea they are just tossed on so I could start it up. I have to reroute alot of the wiring to clean it up. Ran the rear end for about 20 miles last night on stands. Works good.
Edlebrock says a 2 inch carb spacer will optimize the setup on that intake. If you have room, might give that a try. It did help on my similar setup.
2 more inches holy crap. Lol well this is the victor that has the 1 inch taller the the normal victor jr. So I think I will try this for a bit. You can clearly see the spacer added to the casting here. Most all victor jrs are not this tall. It's a more expensive one as well.
but thanks for the tip. I will probly be running a adjustable ez plate or something close, next spring which is one more inch higher. I can manage about 2 more inches in there tops then the carb will betoo close for comfort to the 4 inch cowl. Right now the 4 inch filter fits in the cowl like a glove.
Yep. Mine is not a Super Victor. Just the Victor Jr. Good luck with your upgrades.
Mines not a super it's a jr. But they make alot of different jrs. Some cnc ones, some taller, the original..exc. one having a 1 inch taller casting, that's what I have.
S60 in and everything is adjusted right. Can feel a major difference with the 4.10 gears over the 3.23s that were in the 10 bolt. Have to work tommorow so no racing but hopefully next Sunday if I don't work we are racing.
That is beautiful.. I hope it works as good as it looks.
Thanks. I know setting up the angles of everything was time consuming. Took me a good hr or so to set the drag bar, pinion angle, and the lca position.
This rear has disk brakes so I added a proportion valve and once I got it dialed in, i have much better control over the brakes. Stopping from 115mph week after week is tiring with the stock stuff. I still have to swap the front stocker set up to the areospace kit I have which should really help alot!
Well im glad i spent all the money i did on the rear end, heads, also I have a xr286r roller cam going in as well, retrofit kit. Because my wife and I are officially expecting out first little fasteddi or eddiette...lol We are very excited. We are both closing in on our mid 30s and the time is now or never. Its a awesome thing.
But thankfully i built on one bad street 385 this year. I plan to finish up the roller conversion this winter as I already have all the parts. Just havent taken it out of service yet, hoping for one nice sunday to race and try the new heads, intake, and rear end out.
you've definitely put together a solid combo man, and it's good you spent the money on the big ticket items now. i can tell ya from first hand that having babies is awesome, but it definitely takes it's toll on the budget and garage time. you have to work twice as hard to be able to spend half the time tinkering.
congrats man!
Thanks Matt. I plan to take the car outta service this weekend and begin the roller swap. Have it all back together asap so that next spring it's just on the trailor and good to go whenever i get a chance. I barly any time now to work on it with work and my appretership but I am a 5th year. Having my journey man's card next spring is the goal. Pipefitter welder. But the car will always be there. So racing in the next few years may be dicey but thankfully my wife loves it as much as I do.
it's a blessing to have a little one on the way. Jr dragster time! Haha. I'm looking forward to this more the I could have imagined.
A suggestion for the younger amoungst us. Kids grow up faster than your hot rods. When my youngest was a year old, I made a contribution to a college fund. When he was 2, I made a second contribution. I was able to lock in a 9.5% treasury rate. I never made another contribution. 15 years later, there was enough there to pay for college at a state college. Nope, not Harvard but good enough. I am following the same path with my grand-daughter using a different type of account. It's up 35% since we started. Doesn't take much to start. Compounding money is a bigger power adder than a turbo.
That's a great suggestion. My wife and I started a college Roth ira last year when we first started to try and have a baby. So thankfully the account is growing and in 18 years it will be way more then enough for a full ride associates to any major college or possibly a bachelors. I have a pretty substantial (for only being 32) retirement account though my local (I'm a ua union member) and also have a Roth ira on the side. So I'm all for compounding monies exspecially when you have 10 15 20 30 years to ket it grow.
I winterized the camaro yesterday. Doing my solid roller cam swap soon. Gotta finish up putting on all the parts I already bought before the baby comes as I know he or she will take up alot of our spare time, which is a awsome thing. We are 9 weeks along so we have lots of time for planning exc.
So here it sits but it's always fun to go out and admire it..lol
Congrats on the new addition!
You may think you have time b4 the baby comes buuuuuut it goes fast and then its faster after they are born.
Thanks and thats a good point. I gotta get out and work on that cam swap soon before, one, its freaking freezing outside in the huge pole barn i have, and two, before that baby comes arround. He/she is due in late may.
Here is my year in review for 2017. A much better season then last year when I never even made it to a race because of my moms battle with stage 4 nscl lung cancer. This year was a ton of fun and i won more rounds this year then ever before.
Starting the cam swap today after work. Hope to have that done soon before I have no free time anymore.. I really think the mechanical roller will be a night and day different over the hydro flat t xe268
I haven't updated in a bit so I thought I may as well.
Car is running great and about ready to go race in 2 weeks if the weather cooperates.
So here is where all the modifications from the end of last season went.
The victor jr 2999(1 inch taller then norm), the afr 195 race ready heads(300 cfm), a 2 piece billet timing cover, mls. 027 gaskets to bring quench to .039. Compression fell to 11:1 with 65cc heads, comp xr288hr (236/242 dur@.050 110lsa) roller cam, roller conversion, the 4.10s s60 race rear end package, manual steering box, ptc 4800 8 inch custom converter. All those things went in quite easy. I have a good tune to at least get it down the track, then I can dial it in better. >
I've driven it around a bit here and there. Pretty friendly on the street and fun to drive. Pulls about 13 inches of vac at hit idle 11 inches in drive. Smooth on a gauge with a liquid fill.
Not expecting a terribly fast number come race time but 11.20-11.30 or so would be nice considering my times last year with much less heads, cam, gear, exc. Best of a 11.62@115mph (xe268 cam flat t hydra) performer intake, 3.23 gear, very old as cast iron dart heads.
Nice car and you are doing good job driving it. Seems like you still may be spending a little too much time on going quicker, instead of staying consistent. As long as you are having a good time!
Being that I'm in the 10s and I cant slow it down easily to 11.50 or slower I'm now in the Pro class so it's much harder to do well. And with the baby its tougher to make it to every points race so right now I go every few weeks, but we are going this Sunday. We have a motorhome so that helps. I've only made 6 passes now with this set up and its consistent for the most part. I dont plan to mess with it this year. Just keep racing and hopefully some round wins fall in line lol
