ISO 91-92 trans am or formula
Car: 85 Camaro
Engine: Cadillac 500
Axle/Gears: 9 bolt
Prefer somewhere within a reasonable distance of Oklahoma and under $10k. Must be in clean running condition. Bonus $ for white paint and or gta hood.
Re: ISO 91-92 trans am or formula
I have a 91 GTA black. Motor is already pretty well-built. Bored 0.30 over , windage tray, crank ground , full roller valve train with 1.6 rockers , 220 CC heads , Holley stealth Ram , 36 lb injectors, MSD 6A ignition, Dynamic EFI ebl P4 ECM . Overdrive is shot in transmission first and second still good .
Want a title? Post!
Car: 92 Formula, 02 Tahoe, 08 Solstice,
Engine: 305 V8
I just listed one and I’m negotiable on the price so it doesn’t get snowed in till next spring
Car: 85 Camaro
Axle/Gears: 9 bolt
I ended up purchasing a car spring 2019. If mods see this then this thread can be locked
Car: 85 Camaro
Axle/Gears: 9 bolt
I bought this 85 Trans Am for $2000 then got it running right with a tune up and carb rebuild. Also went through the suspension and threw some wheels and tires on it. Found out someone has already swapped a 350 into it so I've got some Vortec heads and a small cam for it and I'm slowly finishing the interior then it is off to paint
firebirddude142
Exterior Parts for Sale
Dec 19, 2018 10:15 AM
wannafbody
Sep 23, 2007 10:50 PM
