open loop for raceing
Old Jun 4, 2006 | 01:35 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
could you program a chip to run just in open loop all the time if just used for raceing,or how bad is it to run in open loop for extended periods of time?
Old Jun 4, 2006 | 02:10 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
U can run open loop full time or use it for racing.
It just does get more critical and your tuning needs to be more complete for any given application.
U are losing any type of correction for mechanical or electrical failures assuming your car is modified and everything else is tuned to a near 100% perfection rate :-)
Lots of folks here do it, I'm one of them.
If you have the time and inclination and can be made to work very nicely and might suprise you about how things work when your not trying to keep it all at 14.7 AFR.
later
Jeremy
Old Jun 4, 2006 | 02:29 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Closed loop, is for the cat converters, it has nothing to do with engine performance, or it's life expectancy.
Like any tune (running open loop), if it's wrong, it's wrong, and the engine will suffer.
Old Jun 4, 2006 | 06:05 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
[QUOTE=3.8TransAM]U can run open loop full time or use it for racing.
If you have the time and inclination and can be made to work very nicely and might suprise you about how things work when your not trying to keep it all at 14.7 AFR describe"more complete tune"To the best of my knowledge every modification is tuned into my chip.Anything specific i should look out for? thanks
what do you mean if its wrong its wrong.If its not properly tuned?
I am correct in thinking that the car has more power in open loop,right?Or is it just because the engine is cooler.It sure seems to have a great more umpf when its first cranked up in the morning
Old Jun 6, 2006 | 01:32 PM
Bethann's Avatar
Car: 91 Corvette
Engine: 396
What I think he means is:
If you don't have the fuel and spark tables (and others) optimized for maximum performance then even running open loop won't give you good performance. Running open loop allows you to run AFRs less than stoich. Most gear heads agree that running less than stoich gives maximum performance.
I run open loop full time and keep an LM-1 hooked up full time to keep an eye on the AFR...it's a manual feedback system.
Old Jun 6, 2006 | 04:44 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Is this best done by yourself orcan you get someone who burns proms to do it?I mean is it a lot of trial and error,hands on,need to be there or could you do it on the phone through the mail.Is it hard for someone to get it right unless they can actually be there?MY chip has been reprogramed for all my mods.Would it still need further reprograming to run in open loop all the time.And what is a lm-1and where could i get one ,for how much
Old Jun 7, 2006 | 01:59 PM
Bethann's Avatar
Car: 91 Corvette
Engine: 396
Is this best done by yourself or can you get someone who burns proms to do it?
That's a loaded question. The answer depends on how radical your mods are, how much time you have to dedicate to the project or how much money you can spend having someone else dial in the performance.
In general if you have radical mods or plan to, it's worth it to start to learn tuning. Everything you need is on this site but you have to dig for it.
Yes it's lot of trail and error when experience level is low. In my experience using someone else to tune via email or the phone is a drag.
If your mods are radical...yes.
Just one constant needs to be changed...temperature to go into closed loop needs to be set to the maximum.
LM-1 Wideband O2 Digital Air/fuel Ratio Meter
Old Jun 7, 2006 | 05:09 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
thanks alot guys
Old Jun 8, 2006 | 11:38 AM
Ronny's Avatar
i am running CL lately. i ran ol from 09/05 to 05/06. seemed the car ran better when i went OK back in sept. however that i believe was from lack of FP and lack of AE. when i upped FP 10% and upped AE 20% and reverted back to CL 05/06 car ran same as OL yet gas mileage was way better. cruise at 15.0/1 vs 14.00/1 OL. deaccel enlean and hyway mode disabled.
now what i did in OL was to run fueling tables at 122-124 blm. i would flip back to cl to verify 124 once a week. i have no cold air so my tune was developed as far as blm on fully heat soaked engine compartment and 70 deg environmental temps.
ps. with my prominator(awaiting) i should be able to flip CL OL with a click. same with timing tables. click click. pretty cool IYAM.
Old Yesterday | 03:22 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
Re: open loop for raceing
WOW. i just came here to learn how to delete my cold start injector on my 85. Sad to hear this news. Godspeed.
Old Yesterday | 03:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I don’t think $1F has a crank pw table in the code.
Old Yesterday | 05:00 PM
ULTM8Z's Avatar
my guess is you were intending to post in the thread about RBobs tragic passing.
Old Yesterday | 09:53 PM
Larry's Avatar
Car: 86 Corvette
I've been running open loop for years. With a good tune at cruise it stays at 14.7 just like closed loop. I run richer than that at idle and up to 1200 rpms because my cam likes that better.
Old Today | 12:32 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Larry this thread is 20 years old. Ops car is likely crushed by now.
Drone358
Dec 10, 2015 08:16 PM
Nick McCardle
Sep 10, 2015 08:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
Amillionoh7
Sep 5, 2015 11:44 PM
