[OH] EFI CONNECTION, EFI INTAKES, GARAGE CLEAN OUT
Old Dec 22, 2015 | 09:41 AM
etizz's Avatar
up for sale is my efi connection setup, everything is brand new still, it does work, I just went ls1 thanks to a deal I couldn't pass up.
efi connection 24x reluctor, roller timing set with 1x cam pattern, billet timing cover, , and oil pump drive. SOLD
2 valve cover ls1 coil pack mounts for Sbc or lt1 $150
also I have a real (not chinese knock off) holley stealth ram for vortec heads that's brand new as well with some ebay fuel rails, aeromotive fpr, 24 lb lt1 injectors, lt1 throttle body with spacer. SOLD
if interested ill pull my vortec heads off, they are checked/ refreshed from koi with about 10 miles on em, will need valve springs/retainers (I pulled my comp 918 springs off for my ls1) SOLD
also have comp cams magnum full roller rocker arms with poly locks SOLD
also I have a 327 short block: SOLD
350 010 block
machine work (bore .060, use torq plate, new cam bearings, deck .010)
327 crankshaft specialties forged knife edge crank turned .10 mains, .20 rods
eagle sir I beam forged rods
speed pro hypereutectic pistons with 2 valve reliefs
isky z-25 solid flat tappet cam 240/240 @ .050 .480 lift
solid lifters with edm hole
ARP main cap bolts
billet aluminum crank/water pump pulleys
flo-kooler short water pump
melling hi volume oil pump, arp steel oil pump driveshaft
summit 7qt pan/pickup
broke in, ran great have a video I can show, tired of looking at it not in a car I don't have one to put it in otherwise you bet it would be in there.
pictures upon request
Lt1 intake bare with fuel rails $30,
8 Saab 9000 turbo 34 lb injectors SOLD
Edelbrock tbi to mpfi intake $100, one injector boss needs repaired.
gm super victor style intake for vortec heads converted to mpfi, fuel rail mount needs fixed, $100
sbc 2 pc flywheels $20 each
PRICES ARE OBO, I ACCEPT PAYPAL
located in Fairfield ohio. thanks
Old Dec 30, 2015 | 12:07 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: EFI CONNECTION, EFI INTAKES, GARAGE CLEAN OUT
comp cams magnum full roller rocker arms with poly locks $250. Have pics?
Old Dec 30, 2015 | 07:57 AM
etizz's Avatar
I will get some tonight , they' re are these, self aligning for vortec heads, 1.52 ratio http://www.summitracing.com/parts/cca-1617-16/overview/, didn't realize how much of a hit im taking on my price, they have like 5 miles on them.
Old Dec 30, 2015 | 08:00 AM
etizz's Avatar
HSR intake combo sold
Old Jan 1, 2016 | 08:53 PM
monte87cortez's Avatar
Car: 1989 Camaro Iroc-Z
Axle/Gears: Bw 9bolt 3.42
Any pics of clutch? And a part # also didn't see a price I might have missed it too
Old Jan 1, 2016 | 09:00 PM
etizz's Avatar
Efi connection kit sold other than the coil brackets
Old Jan 1, 2016 | 09:03 PM
etizz's Avatar
Text me and I'll send pics 5139696156, it's a ram power grip pressure plate with a center force dual friction clutch disk 26 spline, literally .2 miles on it I drove around the block before I noticed an oil leak from the rear main . Arp bolts. I'll take 250 shipped
Old Jan 5, 2016 | 03:47 AM
etizz's Avatar
Vortec heads and rocker arms sold
Old Jan 30, 2016 | 11:00 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Is your Flo Cooler water pump standard or reverse rotation? Miles?
Old Jan 30, 2016 | 12:46 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
How much for the lt1 cam shipped to 08527?
Old Feb 1, 2016 | 08:55 AM
etizz's Avatar
updated list, cams sold, water pump goes with engine, standard rotation
