[PA] Parting out 1987 Trans Am GTA
I am parting out a 1987 Trans Am GTA. Car ran and drove up until today when I started taking it apart. Motor ( 305 TPI) ran really good. ( have video) but smoked a little have new heads I will sell with it. Trans ( 5spd T5) shifted petfectly, no grinding or weird noises. Posi rear which has 3.45 gears ( G92 performance package) works perfectly. Body is good shape except floors were heavily rotted and drive door has a little rot in it. Price list:
1) front/rear WS6 coil springs $40
2) Front sway bar $25
3) Brand new Monroe shocks ( literally less than 1 mile on them. I put them on this past Friday on the car so I could test drive it safely) $30
4) Y- pipe w/ catalytic converter $40
5) brand new radiator $60
6) T5 bell housing $40
7) slave cyl assembly $25
8) (2) flywheels $ 25
9) (2) clutches unknown brand/ miles $25
located in Hatboro,Pa
Transmission: Pro-built 700R4
Re: Parting out 1987 Trans Am GTA
What steering wheel is that?
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I did get my emblems. Thank you. If you find that front bumper emblem please let me know.
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
I'm interested in shocks and Maybe springs still deciding if I want to just go with new springs. Shocks coming to 15201 if you can get me a shipping cost. And a few pictures if possible of shocks and springs you can send them to 4128052698
Car: 1984 Z28 HO
Engine: 5.0
Does it have the dual cooling fan setup? If so how much for the fans and both upper & lower mounts? Is it a stock radiator?
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Interested in the ecu chip. But I'm interested as to how the car ran with that setup? I have a 305 tpi 5 speed myself and I'm curious as to what kinda performance gain you get with this.
Car: 1986 Trans Am
Engine: 350 sbc
Is this a more updated list? I see more on your local ad, interested in a few things there that aren't here.
-Tommy
-Tommy
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Would you see just the bolts the mount the t5 to the bellhousing ?
Want a title? Post!
Car: CharlesOdory
Engine: CharlesOdoryOB
Transmission: 87822978114
Axle/Gears: CharlesOdory
I am interested in the y-pipe and exhaust manifolds. I will PM you.
