l76 6.0 to 4l60e.
l76 6.0 to 4l60e.
Just picked up a l76 6.0 off a 09 g8 and i have a 4l60e off a 4th gen Camaro. What flexplate do I need for this combo? Could I use the same ls1 flexplate my trans came with or would I need a spacer? New to all this. First ls swap just trying to get this right. Any info helps thanks.
Re: l76 6.0 to 4l60e.
The Flex-Plate for a 4th-Gen F-Body is all that is needed.
Make absolute certain to measure the Torque-Converter to Flex-Plate spacing.
1/16" to 3/16" of spacing is required with 1/8" being ideal.
Use drill-bits in those 3 sizes between the Torque-Converter mounting pads and the Flex-Plate to measure the space.
Use washers between the Torque-Converter and Flex-Plate to adjust the spacing if needed.
Then YES, you can use the Flex-Plate with the 6.0L block/ engine.
Ok thanks that's what I thought but wanted to make sure. I got l76 bored .020 stage 4 tsp cam 799 heads tbss intake and flavor pistons I want to convert it to flex fuel but need to find a good 4k stall converter
Brando5641
Dec 20, 2014 02:48 PM
