Will my T5 bolt up to a 350 TPI
Old 04-28-2024, 07:55 PM
jleuer's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
I have a 1990 305 RS I have a 5 speed manual and am not exactly sure if a 350 will bolt up to a t5 I want to engine swap but I want to keep the trans thats currently in it. If it does bolt up will the t5 handle a stock 350? Thanks
Old 04-28-2024, 08:12 PM
Received 1,688 Likes on 1,283 Posts
Re: Will my T5 bolt up to a 350 TPI
Yes. Depending on certain variations such as the 350's year model. (2-pc vs 1-pc rear mani seal, and as a consequence, the flywheel)
Maybe. Depends on how you drive it and how long you consider to be "holding up".
Old 04-28-2024, 08:18 PM
jleuer's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Im not super knowledgeable on what im looking for how can you tell the difference between the 2 and what one would fit a t5?
Old 04-29-2024, 08:27 AM
Both "fit" the T-5 exactly the same. "Fitting the T-5" isn't the potential issue.
The part that might be different will be the flywheel. Look at the rear main seal on the 350 you have. Count the pieces. If there's only 1 piece with a completely round flange on the crank for the flywheel, it's 86-up, and your flywheel will fit it. If there's 2 with a funky oddball shaped flange, you'll have to get a flywheel for 85-back. It will need to be a 12.8" one; 153 teeth on the ring gear.
Old 04-29-2024, 08:40 AM
jleuer's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Thank you very much I plan on buying a 350 from marketplace and rebuilding it to swap it i just wasn’t exactly sure what I was looking for.
Old 04-29-2024, 09:15 AM
Tom 400 CFI's Avatar
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
I ran several T5's (or, one T5 rebuilt several times) behind a 305 CFI...we all know how powerful THOSE are! I broke that T5 over and over again. I even broke the shifter off of it once!
I ALSO, ran a T5 (just one), in the same car, behind a SBC 400, and ran it for years, drag-on a regular basis. 1 or two nights a week at our local track, all summer(s) long.
What was the diff?
1. The 400 had way more power and torque
2. I learned how to drive and be mature about it. By that, I mean, I learned the difference between just tooling the **** out of the trans (and car) -which accomplished nothing and inevitably broke something....and driving it FAST, w/o breaking parts. In all of the time behind the 400, with all those drag track passes, I broke 1, 3/4 shift fork.
Sofa is absolutly right. "Maybe". With a serving of 350 and a side of dumbassery, you could go out and trash that transmission in less than a week. Or you can drive/shift/lauch with judicious application of load on the trans and it could last for years.
Old 04-29-2024, 08:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Since you have a 90, look for a 87 an up roller cam block.
Don't fall for the high nickel 4bolt main 60-70s blocks are better bs
jleuer (04-29-2024)
Josh R
09-06-2008 03:10 PM
Gibson20
12-28-2005 10:10 PM
MOCCASIN
10-29-2003 05:51 PM
BadBird84
10-01-2002 09:58 PM
ChevyGuy87
11-16-2001 07:56 PM
Quick Reply: Will my T5 bolt up to a 350 TPI
