Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
Finally got myself a 1991 Camaro RS with the 305 5 speed. Starting this thread to document the build. Looking into doing the Ls swap and t56. Looking to find a 4th gen Camaro. I know it needs paint. Only one rust spot and it’s in the trunk area on driver side.
I hope the rest of those seats look as good as the driver's seat bottom when you pulled back the seat cover. Wish the ones in our '92 looked that good!!
the bottom has a small tear but the rest are clean. I plan on swapping them for more of racing seats later on
Very cool and exciting. I documented my LS swap here, check out my thread or send a PM if you have questions. I'm looking forward to seeing yours completed
My rust spot to patch Started tinting my taillights
Still been fixing all the little rust spots. Got one more left and started tinting my taillights. With the spray tint I had an issue of wrinkles and sanded back down and will try again.
Have the car fully gutted and taken apart. So now it’s onto sanding and painting. Gonna do a full tubular k member and control arms. Some weight jacks. Looking into the pan hard bars and control arm for the rear.
Began replacing the infected rust with part panel piece that’s clean Roll cage. K member. Control arms. Weight jacks. And maybe more suspension components Roll cage hoop
Got some more sanding done and the last of the metal work finished up. Looking sometime next month to get it in primer and starting putting suspension on. Then still need to find a donor 4th gen to use for drivetrain plus little other stuff.
whats the plans for the next steps?
epoxy the whole car than start body work?
basically. Got some infected spots from rust spots. Gotta do some rust conversion stuff to prevent it coming back. I’m really not a body guy but learning as I’m going. Still got underneath to do and that and the engine bay is going black.
