Battery dying on 84 camaro
Old Apr 30, 2026 | 11:43 PM
Mr.Freshies's Avatar
Car: '84 Camaro
Engine: 350 V8
Hi all, on my 84 camaro base (with a 350 swap from an old C10) the battery keeps dying. I dont think its parasitic draw because the camaro was down for about 2 weeks and cranked right up without charging the battery. But if I drive it for a while slowly the lights will dim/stop working and I wont be able to start it if it has been stopped. I experienced this issue a while ago, replaced the alternator, and it still had the issue. I summed it up to parasitic draw but it happened again today after I drove it from sitting for a few weeks.
My only guess is maybe somehow the alternator isnt charging the battery completely because I can drive multiple hours on one charge. (It was also a brand new battery in it today).
Also the voltage dummy light has been on but the ecm was deleted so I thought nothing of it.
I would gladly get readings but the bracket got mangled when I took out the alternator waiting on the new bracket now.
Old Yesterday | 06:55 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Battery dying on 84 camaro
The alternator light ("Choke") has nothing to do with the ECM.
It's obviously not charging. Maybe you got a bad one...
Old Yesterday | 07:10 AM
Car: '84 Camaro
Engine: 350 V8
If it isnt the alternator do you know what it could be?
Old Yesterday | 09:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
I had samilar problem. Be sure u have grounds are stalled & cleaned -
Engine to chassis, engine to body. Also, from experience, be sure the alternator (alt) is paint free when attached to the alt bracket.
Had the alt problem ground when I had the alt on my 1984 Trans AM rebuilt & rebuilder painted the alt & thus the ground to engine for the alt was complete.
Due to the alt not grounding, it would cause the alt to overwork, not charge & thus the battery would discahrge.
Old Yesterday | 11:11 AM
Beeman's Avatar
Do you own a multimeter??
Old Yesterday | 05:00 PM
Car: '84 Camaro
Engine: 350 V8
Yes, I do own a multimeter. And the alternator was not painted. Could it have been the alternator bracket?
Old Today | 06:57 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Guessing will only keep you running around in circles; use your multimeter to remove all doubt.
Badboy4lifeRS
Feb 21, 2009 04:10 PM
plasmeh
Jul 24, 2008 12:32 PM
Dr G
Apr 20, 2004 01:41 AM
warrior_91
Nov 6, 2003 11:09 PM
Firehawk1
May 26, 2001 04:56 PM
