which cat with catback?12 in,14in,or 16in
Old Sep 8, 2002 | 07:02 PM
1989camarorsrs's Avatar
What lengh catalitic converter fits(fits best) cause all the name brands are different lengths
catco-16inch
dynomax-18 inch
random technology-11.5 inches
just curiouse cause i dont wanna get the wrong size cat and have it not fit when i order my cat back exhaust soon
Old Sep 8, 2002 | 10:28 PM
:lala:
Old Sep 9, 2002 | 11:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Suggestion: Get a direct-fit cat and cat-back for '86-'91 TPI single cat application. Yes, I know you don't have TPI, but that's the best combo you can get (single-cat-wise).
You'll have to adapt the y-pipe to fit the cat inlet, but that's a small price to pay for the best system you can get. Then, when you upgrade to headers, get a set made for '86-'91 TPI - it'll fit up to your cat, and now you're set!
Old Sep 9, 2002 | 08:51 PM
PONTIACGTA1988's Avatar
or you cab try this :
Max-Flow High Flow catalytic converters are designed to 25% more than stock converters
MAX96001 2 1/4" High Flow Universal Catalytic Converter $89.95
MAX96002 2 1/2" High Flow Universal Catalytic Converter $94.95
MAX96003 3" High Flow Universal Catalytic Converter $99.95
oh yeah heres there number..
Order and Tech 1-713-910-2226 rpm outlet
Old Sep 9, 2002 | 10:45 PM
like i mean, i wana buy the random technology cat but its only 11.5 inches long and the others are 16 and 18. Is the cat gonna be long enough to reach the y pipe since its 4-6 inches shorter.
Old Sep 11, 2002 | 10:20 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i myself put on a hooker catback on and headman headers & y-pipe. the hooker had to be modified a bit (cut off the flange, but i can deal with it for an $80 savings) so i knew everything would not be a perfect fit. i bought a catco 3" cat and just picked up a 2' piece of 3" pipe (better to have extra then not enough). i'm willing to rig it up (not a poor job, just not perfect) because i saved around $100 not getting the direct fit and i can afford the time it takes to get it just right.
Linson
Oct 24, 2025 02:00 PM
racereese
Oct 3, 2015 03:46 PM
