ImageReady help!
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
ImageReady help!
I've opened a JPEG in image ready. I've tweened this image to create the effect of headlights turning on and off. My goal is to save this image as a GIF. For whatever reason, File --> Save Optimized As is only giving me three options (HTML and Images = .html, Images Only = .jpg, and HTML Only - .html). Saving it as HTML and Images will only save one frame, as will the Images Only option. HTML Only saves it in HTML format, but gives me a broken image every time I open it. What didn't I do to make GIF available to me? I'm simply going to leave the program open until I can figure it out, I don't want to do it all over again, it probably wouldnt come out as well next time. Help!
Car: 94 Camaro Z28
Engine: 5.7L
lol, you're the man I was counting on too, Spearson!
It's cool, i'll figure this out. All i'm losing is time, afterall.
It's cool, i'll figure this out. All i'm losing is time, afterall. Member
Car: 89 IROC-Z
Engine: L98 - Stock
I got your back man....went to Help and found it right away.
You see "Images Only (*.jpg)" because your have your Optimize setting set to JPEG. Simply change this to GIF and you'll see "Images Only (*.gif)".
*note: This optimize window is on the top right of the screen. If not go to "Window" ---> "Show Optimize"
Car: 94 Camaro Z28
Engine: 5.7L
Thanks so much, man! I'm fairly new to ImageReady and i've never had to change that option before. What else can I say but, you da man.
Car: 89 IROC-Z
Engine: L98 - Stock
Originally posted by spearson
heh, I just learned something new, I have never seen that tab before, bunch of optimization settings there.. awesome.
And Mark...tight job on your image.
FruityOne
Apr 12, 2006 10:06 PM
