South Central Region Board for the states of Texas, Oklahoma, and Louisana.
CAM + Engine Help
Old Aug 26, 2004 | 06:05 PM
Atari's Avatar
Car: 1991 CAMARO RS
Engine: 305 TBI Bored 40 over
Transmission: th-350
CAM + Engine Help
ok i've finished installing a new cam
SUM-1107 - summit racing cam...
http://store.summitracing.com/partde...artSearchFlag=
into a new rebuilt 305 bored 40 over engine
got an eprom chip made for the stats of the cam... and still having problems.. car won't start.. this one mechanic told me it could be my valves "stock rockers" that are on too tight...
i also think its the timing.. can't find it...
well i'm trying different stuff and running out of ideas...
help thanks
Old Aug 26, 2004 | 06:32 PM
kewl_blades's Avatar
Car: 2x1991 & 2000 Camaros
Engine: 350, 305 & LS1
Transmission: TH-700R4 and 4l60E
More help can be given when you add more detail on the "no start" issue.
What are you doing and how is the engine responding?
Old Aug 26, 2004 | 09:41 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
What exactly are the symptons, do you have spark, did you check your timing. If you set the valve lash your the car wouldnt start do to the valves being open to long or vise versa. Also try posting this in the Tech and General engine board youll get alot more responses. Good Luck.
Old Aug 26, 2004 | 09:50 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
You bored a 305 40 over?
Old Aug 26, 2004 | 10:07 PM
Atari's Avatar
Car: 1991 CAMARO RS
ok well
when i try to start it..
IT cranks and it sounds like every once in a while it gets a good spark and wants to start... but i think i have the key turned on to much it floods itself with gas...
theres spark becuase i've had it running before but i don't know if the guy who was trying to fix it with me "re-adjusted" the valves..
but today when i turned them down 1/4 of a turn to the left " loosing them" it started alittle better "heard more loudness" lol (running straight headers)
thats another thing.. my friend thinks we need to put some pipes and the mufflers on to create some back pressure. he said that might be it...
(((Posting on the Tech help)))
yes, yes i did... why whats wrong with that?
Old Sep 1, 2004 | 06:25 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
You have NO compression!!!! Get a compression test gauge, and back eack rocker stud nut off until you get compression (you'll know when you get full compression). Turn the motor over with the coil DISCONNECTED while doing this. when all cylinders get compression, hook the coil back up and start it, it should work fine. If the rockers are making noise, just tighten them a bit at a time until they stop (or leave them that way if it's only slight and you don't mind the sound...). Good luck.
Old Sep 3, 2004 | 05:08 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I think his valves were set to "Permanently Open"
Old Sep 3, 2004 | 05:15 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Basic Operating RPM Range 3,000-6,500 RPM
Intake Duration 050 inch Lift 234
Exhaust Duration 050 inch Lift 244
That cam is Huge for a 305 ...
What other modifications were performed ?
Old Sep 3, 2004 | 06:06 PM
Atari's Avatar
Car: 1991 CAMARO RS
Mods:
305 engine bored 40 over
new computer eprom chip programed to specs...
forged pistoneds flatop high compression pistons
'67 pushrods, for length
cam...
i think thats it...
well my mech. got the car running....
we gonna go put some mufflers on...
i still don't know how its running, myself but i'ma have this baby running soon
btw any gatherings going on around houston for f-bodies.. i usually go to sugarland import ones..
Old Sep 3, 2004 | 07:30 PM
FbodTrek's Avatar
Same thing happened to me when I first swapped the 3.4 in, Slapped myself for not thinking of that first (you have to remove pushrods to change intake gaskets on my motor). turns out I just tightened the rockers up wrong, they wer all open lol. And for Atari:
There are meets that some of us go to, it's usually not just 3rdgens though. In Humble there is one at Sonic on 1960 and Aldine Westfield. There is one at SAM's CLub in West Houston. And there are ones that we plan ourselves. Let me know when it's up and running good, we can hit the track (I've got some heads in the works right now I'll be swapping soon).
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
