NITROUS KIT W/ PURGE AND RPM ACTIVATION SWITCH, and other stuff FOR SALE
http://www.dfwls1.com/forums/showthr...threadid=10321
details here
I would pefer local sale in Dallas
Jonathan
details here
Jonathan
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I am interested in both the ZZ-4 heads and the RR's.
What has been done to the heads? Condition? Need referbed before installation?
Craig
Craig
They need absolutely nothing!!! I also have the head gaskets and the right length comp cams push rods for this set up. the head gaskets are fel-pro. Everything is in as close to perfect condition as you will find!! let me know asap!!!! shoot me an offer and just so that you know these same heads are going for around $600.00 on ebay. heads alone. i will make the best deal possible!!
thanks
Jonathan
thanks
Jonathan
Car: 1989 IROC Z-28
These are the 58 cc heads-right? Do U have a casting # so I can check they are the ones I am after?
screw in studs?
what springs?
been port/polished yet?
stock size valves or oversized?
Craig
screw in studs?
what springs?
Craig
I have the part # 12556463 they are completely stock they habe the 1.94" intake, 1.50" exhaust and yes they are the 58cc chamber heads, aluminum. they have screw in studs and stock springs from the zz4. they need nothing, just bolt on and drive. let me
thanks,
Jonathan
thanks,
Jonathan
bigjay89gta
Oct 15, 2015 08:04 AM
