South Central Region Board for the states of Texas, Oklahoma, and Louisana.
ideas???
Old Feb 14, 2005 | 11:26 AM
htown_89bird's Avatar
Car: 89 Formula350
ideas???
what is the weight of your ride? mine currently weighs w/o driver 3434lbs... how can i make it lose more weight? any ideas?
Old Feb 14, 2005 | 12:56 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
You could become anorexic. Or just remove stuff that you don't need, spare tire and jack, back seats and passenger seats. If you really want to get crazy you could put on a fiberglass front end and pull the A/C out.
Old Feb 15, 2005 | 09:40 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Re: ideas???
I saw a LONG post somewhere with all the stuff that can be done.
RS Chris listed some basic things right there. Getting more drastic would be things like tubular control arms and front crossmember. Alum radiator. Plexiglass windows. Alum heads. Fiberglass hood/fenders/front clip. remove spoilers/air dams.
You can visit your local racetrack for a whole host of ideas. If its going to remain a streetcar, well then some of these ideas wont be safe/legal.
HTH...
Old Feb 15, 2005 | 09:48 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Seats, spare, jack, debris, lighter exhaust (unbolt everything after the headers ). Doing all of that could asve close to 150 lbs...which is like not having you in the car. At the next gathering, I'm coming race prepped, you can bet on that. I wanna be running close to Sonar on the bottle...I'm fairly confident I can win in a race against afew of you guys now...
Old Feb 16, 2005 | 08:51 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Considering U were running mid 9's in the 1/8th without, I have no doubt U will be doing some spanking. I'm not sure if I want to go up against U!!!
Old Feb 16, 2005 | 11:57 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I have had this list for a long time, don't remember where I found it. All of the numbers after are the weight savings. If I remember correctly, they are just the average differences, not set to any one brand.
Also take note that some of these were already options that came stock on some third gens. Enjoy.
Aluminum Driveshaft 5
Aluminum Heads 50
Aluminum Waterpump 8
Bear front brakes (compared to 10.5" discs) 20
Carbon Fiber Driveshaft 10
Coil Over Front Suspension 35
Fiberglass Decklid 20
Fiberglass Doors (check to see if street legal) 50
Fiberglass Hood 25
Fiberglass Targa Hatch 60
Herb Adams Rear Control Arms 10
Higher Stall (smaller diameter) TC 10
Lexan Hatch Glass 35
Lightweight 16" Wheels 20
Lightweight Starter 10
Plastic Headlights 4
Remove A/C 35
Remove Emissions Equipment 20
Remove Radio and Speakers 15
Remove Spare and Jack 35
Remove Under Bumper Impact Beams (Not street legal) 50
Tubular K-Member 60
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
