South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Summer Meet drag strip matchrace/challenges!
Old May 20, 2005 | 06:06 PM
  #51
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Originally posted by Barry85Iroc
It's on like Donkey Kong!!!!!!!!!!! I also need a rematch with Rocky, but he hasn't been around lately.
Dont make me have to kick your *** again.....
Rematch it is...
Old May 20, 2005 | 06:56 PM
  #52
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
TexasLT1 - dont tease me about the clutch! But hey, maybe you could let be borrow it?
Barry - go build a real car then call me.
Old May 20, 2005 | 09:34 PM
  #53
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I would like to take Rocky on in the vette..
we had a little impromptu match one time and I was taken...
The car is a little different now, and I would like to retry that
Old May 20, 2005 | 10:38 PM
  #54
TexasLT1's Avatar
Car: '92 RS
I tell you what, its sitting in the shop right now, I'll let you break it in for me, then I'll take it back when I get home in 2 weeks. Oh wait, sorry, its an LT1 clutch
it's all good man, just yankin your chain, I know too how hard it is having to wait on the parts you need. I definitely want to give you a run when you do get one, I know you've got a strong car.
Old May 21, 2005 | 10:26 AM
  #55
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Rematch it is...
Cool! Did ya get the trans fixed? Beating you would be so much more fun than beating Mikey's slow piece of sh*t.
Old May 21, 2005 | 10:27 AM
  #56
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Rematch it is...
Old May 21, 2005 | 11:11 AM
  #57
Rock90rs's Avatar
Axle/Gears: 3.08
hell yeah, sounds like fun!
hehe 2 races for me!
Old May 21, 2005 | 11:14 AM
  #58
Rock90rs's Avatar
Axle/Gears: 3.08
not fixed, only "patched". It should be good enough to make a few passes. shooting for 8.60's and solid 13's!
Old May 21, 2005 | 12:39 PM
  #59
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
8.60's ......hmmm.......that's right in my range!
OK after U 2 get through beating on each other--I'll take the winner!!
UNLESS YOUR SKIRRRRRRED!
Old May 21, 2005 | 03:48 PM
  #60
Rock90rs's Avatar
Axle/Gears: 3.08
well i ran in the 8.70's last time out. So im hoping for better but the odds of that are slim. but who knows, a tune up and a tweak of the timing may be able to pull it off.
Barry, steven, and yourself, should kick my ***. Especially in the 1/4........****ing LTR
Old May 22, 2005 | 01:06 AM
  #61
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hey, there's nothing wrong with long tube runners!!
You're on (HRP not HMP though). I hate how HMP barely has any braking room after the traps.
Old May 22, 2005 | 01:16 AM
  #62
TexasLT1's Avatar
Car: '92 RS
you're damn right its gonna be HRP
Old May 22, 2005 | 09:12 AM
  #63
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
That's OK. If she pinches a loaf, you can use my AAA. You can also use my AA, or my AARP.
Old May 22, 2005 | 10:12 AM
  #64
Max Dunlap's Avatar
Car: white 3.1L'90 v6 Firebird
You need to install a parachute.
Actually I hate HMP too because its so disorganized and small parking area
Old May 22, 2005 | 06:52 PM
  #65
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
I'm running shorties.................
Old May 23, 2005 | 11:06 AM
  #66
Rock90rs's Avatar
Axle/Gears: 3.08
That is a matter of opinion.....
They do come in handy when removing tree stumps..... which i so often do with my car..
Old May 26, 2005 | 03:20 AM
  #67
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
It would be cool to have a dallas vs houston race
Old May 26, 2005 | 09:21 AM
  #68
Zap Racing's Avatar
Car: 1989 IROC Z-28
Come on down!
Old Jun 16, 2005 | 03:29 PM
  #69
TexasLT1's Avatar
Car: '92 RS
just wanted to let everyone know, since esc isn't going, I WILL rule the track
T-56 + Spec Stage 3 + 4.11's + Nitto's =
*correction, since esc is a possible no show.
Old Jun 16, 2005 | 10:02 PM
  #70
Zap Racing's Avatar
Car: 1989 IROC Z-28
Do redlights count?
If they do and that's a clean win, then I'll run U even though your about a second faster.
Old Jun 16, 2005 | 10:58 PM
  #71
TexasLT1's Avatar
Car: '92 RS
thinking of jumping the gun a little craig?
but, as usual, I may have spoke too soon. I've got a pretty bad vibration that comes in about about 65-68 mph and seems to get worse up to about 75, then seems to stay the same up to about 100 mph. I tested this by pulling off the wheels and rotors, setting the rear on jack stands, throwing it in 6th and slowing bringing the rpm's up. At first I thought I'd get lucky and it would be a wheel, but pulling the wheels off made no change. I found one post that suggested flipping the driveshaft 180* in relation to the pinion yoke, tried that and still no change. I just hand the driveshaft dynamically balanced and new Spicer U-joints put it at Houston Driveshaft, so it *shouldn't* be that. The only other thing I can think of is pinion angle since I made a new crossmember. Anyone know how to check it?
Old Jun 17, 2005 | 09:05 AM
  #72
Zap Racing's Avatar
Car: 1989 IROC Z-28
When did the vibration start? Experiance has taught me that just because the driveshaft was rebalanced, it may not be right!!!
Years ago when I was roundy round racing, we had a driveshft made to length and balanced for a dirt late model (1 BAD A$$ CAR--WON 4 FEATURES AND POINTS CHAMPIONSHIP--UNFORTUNATELY I WAS NOT THE DRIVER)--we had a horrible vibration in the driveline--drove us crazy, until we sent the driveshaft back to be checked again--it was balanced wrong!!! Also make sure U have not thron a weight!
Pinion angle--I have an explanation instructions from when I got the Spohn torque arm that explains how--it came with a floating degreed "level/ angle finder"--your welcome to use it if needed!
Old Jun 17, 2005 | 09:10 PM
  #73
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I once had something like that. I had twisted my drive shaft so that the 2 u-joints no longer lined up properly. One day when I was doing about 80 (the vibration smoothed out some over 75) the back 6"s of my transmission broke off. The case was scrap, but I managed to limp home (about 60 miles). Then all the transmission fluid poured out of the gaping hole in the back when I tried to go up my driveway.
BTW, I'm still not sure if I will make it tomorrow, but even if I do I'll probably have skip the track.
Old Jun 17, 2005 | 09:33 PM
  #74
TexasLT1's Avatar
Car: '92 RS
yeah.....I don't want that to happen....
actually I've isolated the vibration/noise to the diff, 99% sure its the front pinion bearing. pulling it in just a few to check it out. if it checks out good, then I'm SOL I guess because I can't think of anything else it could be.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
aaron7
Sep 30, 2015 09:15 AM
JSDaddy189
Sep 26, 2015 03:50 PM
