South Central Region Board for the states of Texas, Oklahoma, and Louisana.
steering wheel slop
Old May 6, 2005 | 10:12 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
steering wheel slop
I need some info on fixing the slop in my steering wheel....I saw an article in a mag. about it and I didn't pick it up..... thanks in advance ,Mike
Old May 7, 2005 | 09:03 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: steering wheel slop
The slop can be caused by several things. It could be some sloppy front end parts tht need replacing, but assuming they are good and the play is in the steering box itself, there is an adjustment in top of the box that U can tighten up some of the slop. There is a nut that U loosen where there is a (I think) a slotted screw (flat head screw driver) that U turn that moves the gears in closer to each other inside the box. I can't remember which direction u turn it to tighten or loosen. u have to be careful, cause if u get it tight in the middle where the gears are worn, when u get to turning the steering wheel it will make it TOO thight, and it will not return to center like U are used to.
Check the appropiate tech board on here and possibly do a search for "steering box slop" or "adjustment"
Old May 7, 2005 | 10:05 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
found it
I used the search and found what I needed......its that F'ing tilt that is giving me problems.....I'm headed to napa to get the tools I need for it....wish me luck
Old May 7, 2005 | 10:07 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Re: found it
OOOPS.....sorry I misunderstood what U were referring to. Yeah, the slop in the tilt wheel is from a bushing in the column. Been there--Done that!
Old May 7, 2005 | 01:32 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
SOB
well I got it apart thanks to a friend @ the chevy dealer......not what I thought it was......the rear bearing fell apart on me.....dealer only part and the dealer is closed untill monday......called the closest junk yard and they are closed on weekends....I should have done this when I was still in Houston......I'm @ my moms house in central Tx...... we will see what monday brings.....
Old May 10, 2005 | 07:43 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Finished it Monday around 1 ish.........took me about 3 hrs......that's due to the fact that I took it apart about 5/6 times to make sure I had it right.......the dealer got me good on the bearings...$50......owell I needed them and now I know my column is good for a few more years......
Old May 10, 2005 | 09:45 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Old May 20, 2005 | 01:30 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Bearings
Hey Mike. I think I am having the same problem. What bearing was it that you replaced? I first thought it was the torx bolts, but I took it all apart and the torx bolts were still snugly seated. I talked to a repair man but he told me that it would cost about $100 in parts and $150 in labor
There is no way in hell I was going to pay that $150 labor when I know I can break it down and put it back together myself.
Can you describe the kind of slack you had? In turning the car left in right it's fine, but when I tilt the wheel up and down to exit the car, I have about an inch of play up and down
Old May 21, 2005 | 07:44 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
take a look at the pic at the bottom....you will see the bearings in the bottom left pic. http://www.autozone.com/servlet/UiBr...3d8016444f.jsp
Old May 21, 2005 | 08:29 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
hitman, where are you located at in houston,..... i have 2 new never been used bearings that where part of the rack kit from back when i use to do stolen recovery work that i just found.
Old May 23, 2005 | 11:52 AM
hitman's Avatar
cool
I live on the far north side of town, near the big airport. How much ya want for the parts??
Old May 23, 2005 | 06:08 PM
DENN_SHAH's Avatar
im over close to the budwiser brewery.
would $5.00 work?
Old May 24, 2005 | 12:12 PM
hitman's Avatar
Way cool
That's fine with me
When is a good time/date to make the deal happen?
Send me a PM and we can work out all the details.
Old Jun 4, 2005 | 07:06 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
hitman.....did you get it fixed....if you need some help drop me a line and I'll help if I can,Mike
Old Jun 6, 2005 | 12:50 PM
hitman's Avatar
I appeciate the offer. Denn_Shah was able to help me break it down. I think I may need more parts than the bearings. There is a slotted cup like thing that sits on the race and I think it needs to be replaced. The Locking plate is somewhat out of shape so I'll have to try and hunt one of those down too.
If this gets to bee too much trouble I may just look for another at a bone yard.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
